Topic: Lower rear DS 1/4.... (Read 3249 times) previous topic - next topic
Sweeeeeet !!!!!!!!
In this picture, check out the rear 1/4. I need the piece from the middle of the black trim and down. Enough that the top of the 1/4 would be about 2 inches under the trim. I can trim it down. Not the structure behind the 1/4, mainly outer painted part. The skin mostly.
nothing to report, I will check on monday at another yard
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
As soon as it stops raining I'll get pictures, they probably aren't usable though... Unless you want to do some work to them.
JPC, I'd rather not have to repair the panel, otherwise I'd just repair mine. LOL. Thanks for the help guys.
Thunder, I'm patient, thanks for looking.
Quote from: vinnietbird;366202
no you're NOT. LOL
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I am patient !!!! Now hurry up !!! I don't have forever. LOL.
no go I started cutting and the bondo was flying, and there was a py repair on the bottom from an old rust hole
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Hey,I appreciate the effort a lot. Thanks for trying.
Bump....................
i'll check the bird i robbed the hood off of for MY83T.. pretty sure that car was straight
Thanks a lot. No luck finding one around here any time soon.
Vinnie, I may have what you need.  Just picked up an '87 TC with a mint body that I'm gonna start parting out next week.  I'll keep checking back to see if you got one yet.  Here's a pic.
Yep,I still need it. I'd also like to have that driver side tail light.
Dang, looks like a nice car too.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
