Topic: Gauge Cluster swap (Read 1313 times) previous topic - next topic
Gauge Cluster swap
Will a gauge cluster form a 90 mustang fit in an 88 tbird? I found a deal on a cut panel with gauges but its for a 90 mustang. Any help is appreciated.
Gauge Cluster swap
Negative ghostrider...unless you swap in the ugly '87-93 Stang dash...and that's not exactly as simple as it sounds, neither.
Gauge Cluster swap
FUDGE, was a good deal also, was a cnc'd plate with gauges in it.
Gauge Cluster swap
What cluster do you have in the 'Bird now? If you have the Base digital (digi speedo only) it's a very easy upgrade to an buttstuffog cluster...
It's more involved if you have the full digi cluster though, as you have to swap out a coupla sensors for the new cluster to reflect oil and fuel levels.
Both can have the 199mph speedo mod done, however. Search for W2 mod or 199mph mod if interested. Nice writeup on CoolCats and Sam's FoxThunderCats pages
I've got a '90 Mustang that may be in want of a cool cluster...should you decide you want to sell it...
