Topic: Soooo...... I've been busy lots of wire (Read 4724 times) previous topic - next topic
So, this all started one very hot day when my car wasn't charging well because the battery was low and I had all my acc on. I started to just fix the problem in hand but i was like hey? why do I need all the computer wires across the firewall, then wires started flying then my friend was like I cant get to all the wires with the dash still connected, so that had to come out. I have been screwing with this thing for about a month now, when will it ever end...... I also decided I would never have air so I removed the air box and gave it to sarjxxx, now I have a 5 gal bucket full of wire and a bunck of holes in my firewall, not to mention ALL THE EFFIN WIRE!!!!!!!!!!!:punchballs:But the car should weigh 50-60lbs less. I did the pedal swap and in the process of installing my line lock, WHAT A FRIGGIN NIGHTMARE!!!!!!!
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
those photos scare the  out of me.
these things must have the worst wiring looms in them, Ford mustn't of heard of electrical tape at this point.
in saying that, its something i'm keen to do on mine :|
83 Thunderbird Heritage - Right Hand Drive
95 Falcon GLi
Quote from: EFFalcon;364033
it had some cloth tape that just fell apart in my hands
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
lol it doesn't look any different than when I left :giggle:
hey did you get the headlight harnesses yet?
Wow!
When asked about what I've changed on my car, I say "there are only two things original to the car, the wire harness and the blower motor".  After seeing those pics, I hope the wire harness never goes up in smoke!
holy short circuit Batman!
About how mine looks right now...mine scares the hell out of me, and I swapped from EATC to manual controls...thank god for an EVTM and this place, coolcats, and Carm's site.
Crazy looking mess. Reminds me of when I had to swap a lot of wiring when my fuse box melted.
Ahh yes, I remember those days:
X
When I did this (dash swap) I was stupid and didn't swap the pedals while I was in there. A few months later I did the pedal swap, and it was a PITA
--and that cloth tape Ford covered the wires with was gross. All it did was make the wires sticky.
My next one will be stripped and wired from scratch...
I got about a half step away from doing that when I was putting the car back together and installing the MegaSquirt.
I still might do it, as the car really needs a set of real gauges, even though I'm partial to the stock look.  I also keep thinking about rewiring the whole car with one of those ISIS power systems.
Just checked ISIS website and wow, thats pretty neat. I'm guessing no relays are needed then since it uses those power blocks?
Also chuck, are those scopes infront of your rear wheel functional? If so the are BA.
Quote from: sarjxxx;364045
I know but if you look really close you can see that I spent another 15 hours on it......NOT!!!!!!!!!!
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
The only thing that i'm having trouble is the flash to pass relay only working when I power it up manually, when the key goes on it stops working???? once I figure that out I can start wrapping the wires up and get back to driving. I found this wire loom tape that I highly recommend!!!! I wrapped some wires and have had it in the sun for a week and it still isn't sticky, and priced nice.
http://www.google.com/products/catalog?q=wire+loom+tape&hl=en&safe=off&rls=com.microsoft:en-us:IE-SearchBox&rlz=1I7SUNA&prmd=ivns&resnum=1&bav=on.2,or.r_gc.r_pw.&biw=1152&bih=635&wrapid=tlif131168831788010&um=1&ie=UTF-8&tbm=shop&cid=9193848551971216011&sa=X&ei=gMYuTqOFC-Xe0QHqpuncAQ&ved=0CHEQ8gIwAA#
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
*Hijacking post removed* Btw good work.
