Topic: HID Kit (Read 1480 times) previous topic - next topic
HID Kit
http://plasmagarage.com/XenonHIDconversionKit.html
What do you guys think of the kit they have for the 9007 bulbs? Also do I need to drill and mount a Projector housing in the center of my headlight assembly? I know it says works with OEM housing but? Trying to wrap my head around this. I already stripped and cleaned the headlights which helped alot but compared to my 2002 ranger it leaves much to be desired. Another option I was looking at was a harness sold by rjminjection that puts 14volts to the headlights. Its 80 vs 200 but which would be best in performance.
HID Kit
http://www.theretrofitsource.com/product_info.php?cPath=24&products_id=205
Actually this looks better, from what I sum up these don't need a reflector. Am I right in that assumption?
HID Kit
That kit comes with a reflector housing that you would have to install into the stock headlight housing. Neat idea, but honestly I think they would look really silly in there. Just my opinion.
HID Kit
I have an extra set of housings, think I might try this. Right now I feel unsafe cruising at night, had more than a couple close calls with some deer. One example was 3 in the road and I had to zig between them, luckily none moved.
