Topic: Dream engine build? (Read 3606 times) previous topic - next topic
Dream engine build?
Quote from: 347Thunder;363371
I would take a twin turbo, 5.0L coyote
That would get my attention.
Dream engine build?
Quote from: 86T-bird;363377
If anything other than a lima were to ever reside under the hood of my car, the coyote is on the short list. I'd probly stick to a single snail however.
Currently my dream engine consists of one with 4 intact connecting rods....
Dream engine build?
4.6 or 5.4 with blower, I think the thing I would like most is a "clean motor" all the wiring, vacuum lines hidden. Something I could drive everyday and still abuse.
Dream engine build?
My dream engine in a Fox car? You'll all think I'm retarded, but I'd love to drop a Duramax into a Mark VII. Money being no object it'd be built to the nuts (at least as far as it could be built without affecting durability too much). The rest of the car would be built up so that I could use it to reliably and safely haul a decent sized (24-foot-ish) camper trailer on a North American tour. I remember reading about a fairly stock Duramax engine powering a fox Mustang into the 10's and still getting ~35 MPG. Of course that's a non-Ford engine.
My dream Ford-into-Fox build would probably be something not too retarded, like an Ecoboost cranked up to ~400 horses...
Dream engine build?
Infinitely slow, but I'm working on my dream motor:
X
Should be done by 2025.
1987 TC
Dream engine build?
Start off with Ford Aluminum Big Block going for 800 inch's of joy, John Kaase P heads, 2 T6 turbos and shove it in a pinto wagon
Dream engine build?
Quote from: Thunder Chicken;363449
can i borrow your dream?????
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Dream engine build?
Quote from: SirChirpAlot;363490
Hey, I had 2 of them. they had 69' 429s w/c6s. first one wasn't tubed but the second one was. custom fenderwell headers. Very fun to drive and to keep going in a straight line at the track.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Dream engine build?
Quote from: HAVI;363472
X
Oh yeah!!!
Id love to have a 351C too. Trick Flow makes a EFI intake for them now and Hooker makes swap headers too. I think my dream engine just changed.
Dream engine build?
Here is the build I am actually going to do, but it's also me dream build. :)
Boport Pistons $549.00 or Stinger CP Pistons $580
http://www.bo-port.com/index.php?act...d&productId=26
http://www.stinger-performance.com/suspensionparts.html
Boport Head $1250.00 or Aluminum Borport Head $2950.00
http://www.bo-port.com/index.php?act...d&productId=72
http://www.bo-port.com/index.php?act...d&productId=58
Boport Stage 3 Ported Upper/Lower Intake Manifolds $425.00
http://www.bo-port.com/index.php?act...d&productId=13
Garrett GT35R Ball Bearing Turbo (600HP) $1342.95
http://www.frsport.com/Garrett-GT358...e_p_16163.html
Stinger PIMP ECU w/Tuner Studio $670.00
http://www.stinger-performance.com/universalparts.html
1000cc Injectors (640-700HP) $230.00
38mm External Wastegate $170.00
2.3 to SBF Bellhousing Adapter Plate $175.00
Aluminum Flywheel $335.00
Stage 3+ Clutch $435.00
Short Throw Shifter $75.00
Brembo Big Brake Kit $1500.00
Bullet Proof Edition T5 Transmission (600+HP) $1790.00
http://www.promotionpowertrain.com/TRANSMISSIONS.html
4.10 Moser Gears $190.00
http://www.allfordmustangs.com/forum...sb-list-3.html
Snow Performance Stage 3 Water Methanol Injection $500.00
http://www.snowperformance.net
Summit Fuel Cell $104.95
http://www.summitracing.com/parts/SUM-290106/
Roll Cage $1500.00
Frozen Boost Water to Air Intercooler Kit (600HP) $299.99
http://www.frozenboost.com/product_i...764096411a5ea3
Full 3 Inch Custom Exhaust (header/downpipe/out) $1000.00
__________________________________________________ __________________________________________________ ____________
Total Cost $14241.89
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Dream engine build?
X
I know the feeling LOL
