Topic: Dream engine build? (Read 3605 times) previous topic - next topic
Dream engine build?
If you where to build an engine with no budgit, what would you do. Keep it Fox related (2.3, 3.8, 5.0, 5.8C or W swap, Mod swap, or 460).
After I get around to swapping in my HO, I'm going to start building the SO motor. The plan is is to take my time and cut no corners. I want this to be my dream engine, no budgit.
Parts list
Eagle 0 balance 331 stroker forged crank
Eagle H beams
Mahle 8.5-1 pistons
DSS main surpport
7q oilpan
double roller chain
World product windsor sr. heads or AFR 205s
custom blower cam
Comp magnum rockers
Ported explorer lower intake
Kenny Bell blower 9 psi
and so on.
Im hoping for 550-600 RWHP with a T56 viper spec or TCI six speed.
What would you do?
Dream engine build?
Pro built 5.4 supercharged engine from a Shelby.
Dream engine build?
If I had NO budget... hmmm...
351W. bored and stroked to  427
afr 205'S OR Bigger.
custom grind cam
Weiand 8-71 with dual 600cfm demons
7 qt canton pan
all ARP studs
10-1 keith black pistons
moly file fit rings
Oil cooler
Methanol inj
granted... i'd never be able to drive it it sure would look sweet sitting in the corner though.
Dream engine build?
If money were no object.
FMS Boss 302 block
Eagle Competition forged 347 rotating assembly
Trick Flow Stage 1 cam
AFR 185 heads
Comp 1.6 RRs
Trick Flow EFI intake
BBK 90mm throttle body
JBA long tube headers
Matt
Dream engine build?
Quote from: vinnietbird;363271
I thought about a mod motor like the new 5.0 ($6500 from summit), but I want to build something that I feel comfortable working on.  Some thing that wouldnt make me want to hurt someone.
Dream engine build?
Mine would be dependent on the car it would go in.
For my autox car, it would have to be a stroked 2.3(either 2.5 or tall deck 3.0
Fully ported esslinger arca head with full solid roller conversion
Boport 2.5 cam or custom grind
billet rods
and a turbo that could meet the rules for cp (52mm)
400-450whp
If its a build for my truck
take the 545 shortblock already in there and motorsport A460 heads, twin 1250 dominators and twin turbos.  easy 1500hp
Dream engine build?
Mine is..... anything that will actually run after I get done touching it.
Dream engine build?
Quote from: Bruce M;363234
I'm hoping for 550-600 RWHP
I like your dream engine, I'm in the process of something similar (using a centrifical blower).
If I am reading your thread correctly, you intend to use the SO block?  If so, take a look in the tech section for some pics I posted showing a comparison of a roller block vs an early Mexican block and then a later post with an aftermarket block.
At 550-600 RWHP adding a good block to the dream will help keep all those great pieces from becoming a nightmare.  That is, if it becomes reality:D
Dream engine build?
Quote from: daminc;363329
Jerry, Great line!  There are times when my stuff resembles that remark.
Dream engine build?
I always thought it would be cool to swap a Terminator Cobra driveline into my 'bird.  I've been in love with the sound of those cars since they came out in '03.  I would probably leave it fairly stock except for a pulley swap, full exhaust, and a good tune.  That would be more than enough for me!
Dream engine build?
Quote from: 86T-bird;363336
+1
Don't bother with that block at 400+ HP. It's a waste of money since it will kill your other parts when it goes boom.
Dream engine build?
No budget?  A 427 SOHC in a 41 Willys pickup.
Dream engine build?
Ford:
2.3 based-
Tall deck block, around 2.8 litres after bore and stroke.
Volvo B234 head, ported, larger valves, reground cams, solid "lifter" conversion
Fabbed header
Borg Warner EFR series turbo
Non Ford:
Oldsmobile 425
Stock block/crank
Aftermarket rods (If I could find stock length 7.0" ones?)
Custom ground cam
Edelbrock Performer heads
Edelbrock Performer intake, converted to fuel injection w/1200 cfm TB
Two Borg Warner EFR series turbos
1967 Olds flat top wagon to put it in.
Dream engine build?
Quote from: flylear45;363355
+1
I'd most likely go with the boss block but they make main and valley surpports that are surposed to stop block twist. But if you add up the cost of gridles and machine work it would be better to spend a little more to get the Boss block (it can be bored 4.125").
Dream engine build?
I would take a twin turbo, 5.0L coyote
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
