Topic: dual exhaust question (Read 3653 times) previous topic - next topic
Was the brace across the driveline tunnel really tight against your exhaust?  Mine is pressing pretty hard up against it
Mike
what car is that?
The brace on mine was taken off by the exhaust shop. Things have been fine without it for years.
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
I took mine off when I did the H-pipe
I had pipes bent to fit and it has the E Brake cable running on it
Mine is removed also. I took it off and also removed the E brake cable from the pass side for more exhaust clearance.
Quote from: daminc;362502
what car is that?
My 88 Cougar 5.0
Mike
Quote from: TOM Renzo;362507
So when you use your Ebrake, only one side brakes??
Mike
NO both sides hold just fine.
Quote from: mcb82gt;362510
My 88 Cougar 5.0
Ok... my 87 has a straight brace, that's why I asked
Mine was mangled from the fork lift that loaded the Sport onto the flatbed to bring it to me. So was the exhaust and driveshaft. I don't miss it. Everything holds fine without it.
looks like mine will also be leaving soon then
To my knowledge, single exhaust cars had the straight brace and dual exhaust cars had the bent brace.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
The Sp[ort had it, but it was a duel into single into dual factory exhaust.
I have the "bent" brace and 2.5" Flowtech Mustang mid pipes. They fit fine with about 1/2" of clearance between the pipes and brace.
