Topic: Gasket or NO Gasket..... that is the question... (Read 1511 times) previous topic - next topic
I use Explorer gaskets on my gt40 irons. Like them fine, no leaks, cheap, and easy to find in stock.
Unless you surface grind the header a tad to really make sure you have a perfect surface(and youd probably have an imperfect head surface), youll end up using a little silicone, which is in effect, a gasket.
87 Thunderbird LX
65mm tb, exploder intake, iron gt40 heads, 1.6 rr, a9l mass air swap, 9.5" Billet Dirty Dog TC, Built AOD, 4.10's, 31 spline TLoc, Superior Axles, full sn95 five lug swap.
Will the high temp silicone hold up?
Mike
Yes, I always use gaskets to get the best fit. Last time I used Felpro.
Gaskets, yes.
I always use gaskets. Percy''s.
MR gasket makes a good one for the 302, I use it on my 5.0 header equipped cars
Hi temp RTV silicon only here.
Place a bead of silicon on the header '
Assemble and tighten the bolts FINGER TIGHT ONLY!
Let sit for 24hrs (or longer)
THEN torque to spec.
