Topic: Aerostar aluminum drive shaft (Read 12905 times) previous topic - next topic
Ive looked and looked and have more info than I know what to do with. I want to get an Aluminum drive shaft. The stock one is an inch short. I have swapped in a tko 600 and I'm looking at slicks and want a proper length drive shaft.
I know that an aerostar has been a donor in the past and have found guys that have done it in a mustang.
The problem I need help with is the year and length I plan on cutting it and welding just need a good starting place .
 I can get one made for $400 but the cars getting painted and I just bought a tremec and now I'm broke so $400 is out for a while
        :hick:
Thanks Westie
Crown Vic cop car or taxi drive shaft, cut down, and use the adaptor u joints. Done.
The Aerostar shafts are smaller, and a lot harder to find. 400 dollars to  make it, or just to cut down a shaft for you??? I found a place 100 miles from me that'll do em for 75 apiece...
IIRC the AWD aerostar shaft is a direct fit for a stang, not a Tbird. And like I said, the cop/taxi Vics are everywhere...I can nab the shaft for 20 bucks at my local pick n pull.
I got mine from a Crown Vic cop car for free. Performance drivetrain in Oklahoma City took my aluminum drive shaft from the Vic, my yoke and  from the Sport's spare drive shaft, and used the adapter u-joints as mentioned above and then a nice cut and balancing and I was good to go. It's 4 inches in diameter, a lot bigger in diameter than the stock shaft, so watch your lers. It weighs a little more than nothing.
Quote from: ThunderbirdSport302;360068
The Aerostar shafts are smaller, and a lot harder to find. 400 dollars to  make it, or just to cut down a shaft for you??? I found a place 100 mv
400 to make it. What year vic. Cop ones better the local yard has a dozen 2000 ish cop cars ?
Quote from: thewestie;360080
Yeah, I think one of the ones I snagged was a 2000, the other was a '98...I think they go back several years, too, 95 to current, for alum. shafts...
I got one it's to short for mine, not sure what year it came from. It's about 4" to short. It may fit a stang though.
What is the stock length of the drive shaft for a bird?
An Explorer aluminum driveshaft will also work, but it to needs to be shortened a little bit, but not much. I think it was either 3/4 or 1 inch too long.
Quote from: jonwayne1988;360171
I measured mine today and it was 49" I was having some driveline vibration at higher speeds and traced it to a dent in the driveshaft. I blame Pepboy's since they were the last ones to touch it when they changed my U-joint bearings. I was hoping to upgrade to an aluminum shaft, but I may just order a new stock one since there's no direct fit for our cars.
Mine was cheap to have shortened and balanced, including the new u-joints. Go aluminum.
Ok, you talked me into it, lol. Should I bring anything to the drive shaft shop besides the stocker? Kinda hoping they have the tubing in stock so I don't have to hunt down used parts to be modified.
It would probably be cheaper to get a Crown Vic shaft and take your stocker for the yoke and  and have them shorten it more than likely. I had mine done for around $125.00 complete. Not bad. Ask them how much to shorten one and balance it before you have it made from scratch.
what year crown vic should I ask for at the junkyard? does it have to be a police package?
Read the second post in this thread... ;)
Ok, I guess I'll shoot for something late 90's to early 2000's
