Topic: BAD oil leak (Read 2190 times) previous topic - next topic
BAD oil leak
I just recently did a head swap, i just finished it up today with the final checking of the head stud bolts and i notices there was a bad oil leak. Its all over my cam pulley. Ive adjusted the valve cover gasket acouple times and that didnt held. I had to tap out the cam because the bolt wasnt going in so boport told me to tap it out so i did. So could there be oil coming out of the cam bolt hole or should i replace my ranger valve cover gasket?
BAD oil leak
or is it another problem. The machine shop put in a new cam seal for me and it doesnt seem to be leaking from that.
BAD oil leak
I know when I did my Geo Metro head, I forgot to put in the cam seal. That does make a mess.
Clean it all up with brake cleaner and see where it's coming from.
CoogarXR : 1985 Cougar XR-7
BAD oil leak
Cam is hollow, and filled with oil. Did you put sealer on the cam pulley bolt threads?
BAD oil leak
Quote from: gumby;359219
This
BAD oil leak
lol nope!! i thought thats where it was coming from!! where and what kind of sealer do i put on the cam bolt?
BAD oil leak
I always use that permatex thread sealant stuff. It is white and comes in a little white tube. Kinda comes out thick like liquid paper.
Hoping to help
Stuckman
BAD oil leak
Alright cool! thanks for the help. Is this something i can find at a local parts store?
BAD oil leak
is it thread sealant or the threadlock?
BAD oil leak
thread sealant
Stuckman
