Topic: valve cover breather (Read 729 times) previous topic - next topic
I need that little rubber donut piece that pops into the valve cover that the breather slides into. Any help will be greatly appreciated!
Easy Parts store Help Isle. The should have a bunch of different ones to choose form they might have it by application for our cars also. I do believe they are called PCV grommet. Its best to take what is left of yours and find a match. If you can't find one that is the same you could prob find one that would do the job. Also they should have a book with pictures so you could match it up that way also.
Hope this helps
Stuckman
Ive never heard of a Easy parts store or do you mean some place like Autozone or napa?
Not Easy as the Name of the parts store Easy as in any parts store. Oreilly's, NAPA, Advance,AutoZone all of them carry the Dorman/Motormite/Ballkamp stuff. I'm sure you've seen the Stuff in the red Packages that says HELP  on it. That is the stuff you are looking for they should carry many different ones in stock.
Hope this really helps this time.
Stuckman
Oh alright yeah i know what youre talking about. i used to work at autozone. Thank you for your help! I appreciate it.
