Topic: got me some new tires (Read 7054 times) previous topic - next topic
so my front tires were fine, but were a little dry rotted.(pretty skinny for $140 lol)  I ordered a set of maxxis marauders in a 295/50/15 but they are on back order for 8 weeks but only 4 weeks left!!! I was goung to get a drag radial but 1. they cost 50-75% more. 2. I have a spool and I sometimes get caught in the rain. 3. these have a really cool tread. lol
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
one more full frontal :D
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Nice. Aggressive tread design,too. How wide are they? I like some width at all 4 corners.
the fronts are 165/80/15 the rear are 275/50/15 now, but I ordered 295/50/15  but with the suspension I have it still handles quite well. still waiting on the rears may 5th they should ship out.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I gotta get new rear tires as well. I just replaced the fronts (255-40-17). The rears are 275-40-17. I've been a little aggressive with the skinny pedal on the right lately. The poor tires are the ones who suffer.LOL.
nice!  what size rims are you running?  How does it handle?  My bird had 235's on it when I got it and the handling was  unless you were on the throttle.  Dropped to 205's and it rides like a dream now(except on rough roads, suspension work still needs to be done).
Good question, what size rims do you have. I'm taking a guess and saying 15x10 and 15x5. Just a guess.
nope 15x3.5 15x8.5
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I was only an inch and a half off. LOL.  Do you have spacers on the rear? I have 17x10's out back, and yours look wider. Maybe it's just me.
no might just be the offset I think its 4.5
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
It looks great. Aggressive. you've done well.
I hope they fit on my rims the maxxis website calls for a 9.5 rim but the cooper cobras, and the BFG's call for an 8.5 rim. so I guess i will just cross my fingers:punchballs:
man these tires look bad A$$!!!!!!
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I run Nexxen tires. They have a unidirectional tread pattern and actually perform quite well. Priced right also.
I run Maxxis tires on my Cougar.  Good tire at an even better price.  They're one of the last companies that makes an all-season performance tire in a 15 inch size.
Quote from: vinnietbird;357766
I have some on the vert too.. mine are directional though
