Topic: got me some new tires (Read 7050 times) previous topic - next topic
Quote from: daminc;357827
I have some on the vert too.. mine are directional though
I run Nexxen N3000's. A directional tire with great grip, and very quiet in the corners!
Quote from: jrad235;357835
horrible, horrible, tire when they are cold though.. Grip like glue after about 5- 10 min of driving..
Anybody know if a set of Draglites 295/50/15 off a mustang will fit a 87 T Bird?
No, It's not for sale.............Build your own!:nono:
I believe Nick had that exact size tire  on his car without any issues....
On a sidenote, while pulling the spare out of the trunk on the Mustang last week at the track, I took note that my spare tire was a Maxxis......
I also took note of how light the wheel/tire combo was.....Time to grab a second one and mount them both up front :evilgrin:
Those things will fit? The 275/50/15s look like they will rub with a hard launch! It will look badass if they do work.
http://www.foxtbirdcougarforums.com/showthread.php?11142-PHAT-tires.&p=113596#post113596
http://www.foxtbirdcougarforums.com/showthread.php?10147-87-tbird-biggest-wheel-tire-combo
Looking through the threads I noticed Nick had a Mustang rear in the car.  Weld makes the Draglites in 15X10 with a 6.5" backspace and 15X9 with a 5.5" backspace.
I have a 255 60-15 on the stock 10 holes and would rather that size tire be on an 8 inch wide wheel.  I would think that a 9 inch would be ideal for 275's.
FWIW, if you're rubbing on a hard launch, there's too much squat and not enough forward momentum....
ok, I couldn't take it!!!!!!!!!!! I just ordered BFG drag radials 275/50/15, I couldn't ever get an answer on when the others would come in so......, but they will help me next march at the tremec true street challenge. can't expect to run too well on a street tire.lol
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
295/50/15 Will fit
Just to let ya'll know, 295/50/15 on Weld Draglites that came off a mustang fit and no hammer needed!
so I can finally put my new tires on now I got to do this today:burnout:
m
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
the first set of tracks I forgot to turn on the fuel pump.lol
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Nice !!!!
Good gawd you did that! i would hate to pull up next to you at a red light, just hearing the sound of that thing would make shivers go down my back!
Also i have a quick question, how bad does the cowl hood block your view of the road?
1987 Thunderbird Sport (soon to be GT edition) - In shop getting new paint job and interior work. (put on hold as of 11/2/2010, Resumed and going at it slowly its hard to be poor nowadays...)
Quote from: RareBreed 5.0;360001
 Not bad at all just be a little careful pulling into the gas pump.LOL
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
another. and on this last one after I came back on the road you can see the flaps of rubber comming off, will get a picture when I take them off.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Thanks, My car is in a million pieces its nice to see some smoke from a bird
