Topic: long tube headers (Read 3613 times) previous topic - next topic
long tube headers
anyone know what long tube headers will fit 83 thunderbird with 351w must be 1 5/8 primary at least with 3 in collector
long tube headers
BBK or Hooker, get them for a fox body mustang. You'll have to run a floor shifter if you're using a auto. You'll be fine if you're using a manual.
long tube headers
Why 1 5/8 when you can have a 1 3/4 or even 1 7/8 if you ever go boosted or big heads and cam a 408 loves to breathe. I have a 351 with bbk's 1 5/8 shoties?
long tube headers
He said at least 1 5/8th primary.
long tube headers
I'm pretty sure they don't make a 351 swap LT header any smaller than 1 5/8"
long tube headers
If I ever did a 351 swap, I'd us Hooker 1 3/4".
long tube headers
reason for 1 5/8 is the small trick flow heads 170 I'm using its a coast high 408 pro street with 10.5/1 compression so I don't think I would need any bigger for this year. hopefully 100 or 150 shot of nitrous will make up for it at the track
long tube headers
small heads on my coast high 408 170 trick flow
long tube headers
I was looking at a rpm air gap intake and to match the in flow I was told I need 1 7/8 primaries ? and I would love a set of stainless steel once and done.
long tube headers
Quote from: 83thunderbird;357064
.....if you stick with the 1 5/8"....you're leaving 15-25HP on the table with that CID.  :beatyoass:
long tube headers
even with a small 170 cc trick flow head
long tube headers
Quote from: thewestie;357042
I didn't know they made ANY a/m headers less than 1 5/8"... heck even the 3.8 headers are all 1 5/8"
long tube headers
Headmen makes 1.5" headers four our cars.
long tube headers
wow. I was unaware.
long tube headers
I had the 1-1/2" Headmans when I converted my car over to a T-5 in '93.  With the stock CFI on the 5.0 and 2-1/4" dual exhaust is was a pretty good setup for the stock motor.  Getting the bolts in and out of the header  was a breeze and the plug wires had plenty of room too.
Darren
