Topic: Soft brake question.... (Read 2647 times) previous topic - next topic
I am thinking the Sport's master cylinder is going bad, but not sure. The car has soft brakes, and seem to heat up quick when braking a little hard. No sounds of leaking air from the booster.New brakes on the car, and brake lines with no leaks. They were bled a while back with no real noticeable results. Any ideas?
I had that problem on the 85.  So, I figured air.  When I went to bleed the brakes I couldn't get any fluid out of the rears.  It turned out to be the master cylinder.
Armed Forces Car Club
Eastern Sierra Chapter, California
WEB:  armedforcescarclub.com
I think I may just swap it out.
Make sure you remove the casting lines first :P
Already planned in....and a polishing.
You're a sick man Vinnie. Car looks great, and your attention to detail is outstanding, but I think you need a hobby.
Quote from: jangus;356111
Making shineys...... thats his bag, baby.
Mike
That stuff IS my hobby. It calms me.
Quote from: vinnietbird;356148
My pedals has been feeling a little soft lately. come swap mine out too? lol
The Sport gets to be first. I'll find one asap and get it done. There's a guy a couple of miles from me that has the MS and booster from a Stang (Fox) and I may grab them. I'd like to have the smaller booster.
The bolts on the lines that go into the master cylinder on mine are seized. I've sprayed them a couple of times recently, incase it decides to  out, but they are aluminum, and soft. not sure what I'm going to do.
