Topic: what will she dyno pull to? (Read 5335 times) previous topic - next topic
Mods below + gt40y heads, crane 2031 cam, fms 1.7, 42#
120k ho sb, approx  boost starts 1psi @ 3300  4-5psi  @ 5500
Mustang dyno. My guess 280hp
I think decipha guessed  290
I would be pissed if I only made 280 with an aluminum headed, blown 5.0.  Why only five pounds?
blower
Its a old paxton ball bearing drive model which was designed in the 50,s. Its just my daily street beater and its perfect for that.  your thinking of the novi 2000 that is a beast:evilgrin: if you really want powah turbo is where its at:evilgrin::evilgrin::evilgrin:
I was actually assuming it was a smaller blower from Paxton.  I don't know anything about the older Paxtons so maybe it's not capable of moving much more air than that.
320 hp
Mike
Peak was over 300hp @5500. Torque was 330ft/lbs.
The results were better than I thought.
Maybe that will put her in the high 12's.
Nice!
300+ whp should get you 12s :).
Quote from: thunderjet302;355497
Lol, w/tires spinning????:burnout::burnout:
dyno sheet, video, logs
Here is the dyno sheet and a video. I should have gotten out of it alot sooner. :punchballs:
http://s1194.photobucket.com/albums/aa373/tbirdsc/?action=view¤t=tbirdyno.mp4&newest=1
That's a goofy plot. It doesn't show rpm to HP or torque, really. What I read is about 325 hp and 350 tq in the 4th gear pull. Is that all they gave you?
That vid is music.
Quote from: Bruce M;355677
That vid is music.
I must admit, I popped a chubby while I was watching it ...
That graph is weird.  It looks like about 320hp and 340ft./lbs. with 6psi but it's really hard to read the way it is.  Was the pull in 3rd or 4th?  Afr looks good, what's your timing like?
