Topic: Blue by You - TC+4 (Read 49631 times) previous topic - next topic
Blue by You - TC+4
Reply #165
Jon, I think that the power seat tracks at the lowest setting are lower than the manual seat tracks, assuming the same seat is used.
I could get my head further from the moonroof structure with the power seat bases, as opposed to the fixed setting of the manual track. Seat's recline wasn't adjusted..it stayed constant. Hope this helps..
My car also has the moonroof, not the pop up sunroof, in case that makes a difference.
Blue by You - TC+4
Reply #166
That does help.  Thanks thunder.
The seat foam "adjustment" I made seems to work just enough for me to clear the moonroof.  Plus I feel like I'm held in place better by the bolsters - because I'm lower in the seat.  I'm very happy with it.
Flylear, how is your seat dye holding up?  I plan to dye my seats gray.
Blue by You - TC+4
Reply #167
Its holding up pretty well. I am quite happy with the wear so far. It is a little 'crunchy' at first, but softens with time.
I will use it again if a project presents itself.
