Topic: Carl's Road Racer (Read 15826 times) previous topic - next topic
Carl's Road Racer
So... the car started running lean and I couldnt figure out why. Come to find out, my strainer tore and a bunch of dirt clogged up the pump. I cleaned it out and the car is running better than ever. Put some E85 in to take advantage of the new lines and injectors. Ive picked up a substantial amount of horsepower.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Carl's Road Racer
2011 Parts List Update
Things I have left to buy
Boport Stage 3 Head $1250.00
http://www.bo-port.com/index.php?act=viewProd&productId=72
Boport Stage 3 Ported Upper/Lower Intake Manifolds $425.00
http://www.bo-port.com/index.php?act=viewProd&productId=13
Stinger PIMP ECU w/Tuner Studio $670.00
http://www.stinger-performance.com/universalparts.html
Short Throw Shifter $75.00
http://www.stinger-performance.com/suspensionparts.html
Roll Cage $2000
2004 Mach 1 Mustang 8.8 rear with 11.5 Vented Disks ABS 355 Gears $800
Cobra 13in Front Brake Conversion $400
Aeromotive A1000 Fuel Cell $800
Chuck's Motor Mounts
Things I have already bought
Innovative Wideband
Stinger Intercooler Piping and Big NPR Front Mount Intercooler *installed*
Holset HX35 with Billet Wheel Oil/Water Cooled Center
Hallman Manual Boost Controller *installed*
Corbeau Racing Seats *installed*
E85 Fuel Lines *installed*
Lucas 120lb Injectors
Boport 1.9 Cam
Spec Stage 3+ Clutch *installed*
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Nice!  Have you taken it to the track lately?  I'm sure you would beat tyour 15.8 time.
Carl's Road Racer
Unfortunately I have not had time.  Another thing is I think the Walbro is dying because it's still running lean on pump gas.  Sometimes it will run fine and other times it leans out.  There is probably a bunch of dirt that got in the pump.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Some of the recent work I've done
Rebuilt all injectors, cleaned fuel rail, installed Kirban FPR
New flywheel and pilot bearing
SPEC Stage 3+ Clutch Installed
Bellhousing cleaned and installed
Just a recent pic of the bird :)
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Ordered an Aeromotive Stealth 340lph.  Should be in by wed or thur. :)
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Welp... my fuel rail just cracked... right below the fpr. Is this common?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
I crimped my fuel line, and am going to finally run E-85 lines the entire length of the car.  (before I only had E-85 to replace the non metal line)
2 Questions.
How many feet of line do I need to accomidate the feed and return line?
What size should I go with to support 300-500whp? On an Evo site I read 3/8th for feed and 1/2 for return is good. Can the feed and return both be the same size?
Sorry for not posting in a while. I was hybernating this winter!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Why run a smaller feed line than return?? I'm thinking that with running E-85 you'll need the bigger feed line. Someone should chime in that would know more about that than me as I'm toying with the idea of running E-85 all the time but haven't figured out what I need either, besides, I'm not that far along.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Carl's Road Racer
Reply #39
wait.. what?! 1/2" return line?! 1/4" is more realistic, but that's too small if you ask me.. 300-500hp will live happily with a 3/8" feed and return line.. i think what you may have stumbled across was for a turbo's oil lines.. that's the only sense i can make of 3/8 feed and 1/2 return
Carl's Road Racer
Reply #40
Oops... I meant to put a 1/4 return line in my question.  Not 1/2.  Either way it doesn't matter.  I just installed 3/8 for feed and return.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Reply #41
with 3/8 feed and return, you should be in good shape.. i don't remember, but i think these cars came with 5/16" feed lines and they're 'ok' up to about 350hp or so.. some people squeeze more than that out of them
Carl's Road Racer
Reply #42
Quote from: Shadow;385589
The lines I am using now are temporary until I decide on a path for 3/8 steel lines.
With the Aeromotive 340 now installed, I am going to experiment with full E85 and a 50/50 mixture.  Mess around with fuel pressure... etc.  I should have the right combo by the end of the weekend.  Mind you, this is also temporary until I install my 120lb hr injectors and Standalone ECU.  Then I should be able to run full E-85 on full Boost.
I will post some install pics tomorrow.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Reply #43
I was just reading in the May 2012 MM&FF an article that when running E-85 that you basically need to increase the size of the feed/return lines due to the fact that you need a larger volume of E-85 compared to the size needed for gas at a given hp level, that's because of the lower energy output of the ethanol compared to gas. As far as fuel mileage goes, I can live with a 20 - 30% decrease in mileage over the higher price of 93 octane.
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Carl's Road Racer
Reply #44
Quote from: 1BadBird;385614
I have personally seen 75WHP gains from a good E-85 tune.  There are several hurdles if you want to see those gains.  ECU needs to be aftermarket or mapped for E-85.  Injectors need to be approaching 1000cc or better.  Fuel lines need to be 3/8 or better.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
