Topic: Carl's Road Racer (Read 15814 times) previous topic - next topic
Carl's Road Racer
Reply #45
Ran the lines and all... but forgot to install a filter in line.  I only ran the car around the block.  Anyone think that did any major harm?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Carl's Road Racer
Reply #46
Alright, so I ran seafoam through the vaccuum line.  Followed the instructions and everything worked great.  Throttle response is much better and it got a good clean.
I finally found the problem though.  When the carbon was burning off, smoke pored out of two small cracks in the manifold.  One that I knew was there, the other I had no clue about.  To top things off, the gasket that connects my turbo to the manifold is bad too.
I am convinced this was causing my bad A/F Ratio and various other problems with boost response etc...
I am going to go aftermarket, but was wondering what is the better option.
Bob's Log Header
I hear it's very durable, and there is provision for EGR.  Not something that really concerns me, but it's nice to have.
Stinger's Header
I am leaning towards because of the ability to take the turbo off with relative ease.  Also, I am going to need an external wastegate to run an HX35 properly.
Does anyone have experience with either of the two?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Reply #47
i've seen a few horror stories with the stinger header cranking and the wastegate  snapping off.. never heard anything bad about the bob's log
Carl's Road Racer
Reply #48
Quote from: Shadow;385880
Bob's it is then!
Now... I have to decide if I want stock mount or center mount.  I think it might be easier to fit that Holset with center mount.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Reply #49
Just got Stinger's "PIMP" ECU in the Mail.  Now I can put my 1250cc injectors and Wideband on and use E-85!  Wooo!  Dyno run soon to come!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
