Topic: Carl's Road Racer (Read 15275 times) previous topic - next topic
Carl's Road Racer
Maximum motorsports coilovers here.  I think I should've gone with koni's, but I bought all the bilstien stuff.  650# in the front, 500# in the rear.  I should probably go higher in the rear because in a hard corner, it still picks up the inside front tire off the ground.
Carl's Road Racer
Just got
Boport 1.9 Cam
Holset HX35 with rare oil and water cooled seven blade billet wheel and vband internal wastegate
Hallman Pro Boost Controller
SPEC Stage 3+ Clutch
Pics to follow as they come in the mail!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Carl's Road Racer
Hallman Pro RX Boost Controller Installed
Works great and as advertised.  Low boost spring gives me 5 extra PSI over stock as advertised (from 10 to 15) I have yet to try the high boost spring (advertised to give much more but I'm going to set it to the 18 PSI the gillis valve failed to hold)
Turbo spools up a lot quicker!
Very Rare version of the Holset HX35 with
-Billet Wheel
-Water and Oil Cooled
-Internal Wastegate with 3in Vband
-T4
Wheel is tight in all directions and spins great!
Paid $380 bucks!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Quote from: vinnietbird;365530
I think an inch and a half to two inch drop is good. If you get the car to low, it loses it's usefulness. Have to come to a near stop to cross a speed bump. Not worth having a car that drags or easily bottoms out for the sake of looks.
Adjustable coilovers would be nice though... So you can lower it further when you want to play, but leave it a little higher when daily driving.
Carl's Road Racer
Id run the boost controller inside... I can tell you it is much more tempting to bump it then. Boost is like a drug.
Carl's Road Racer
Quote from: DVP;367633
No real need to do that untill I run the holset.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
How much weight do you think I will save from:
Full Fiberglass Front Clip
Hood
Trunk
Doors
Lexan
I was guessing 400 to 500 lbs?
http://www.hairyglass.com/thunderbird.html
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
I don't know how much the doors weigh, I can only assume at least 75+ pounds. I know the hood is heavy itself. I would say around 300-400 easy. I don't know about 500 though. The decklid, windows and front cover/fenders don't weight that much.
Carl's Road Racer
Quote from: Carl;367699
Hood
Trunk
Doors
Lexan
Actually all the parts are Carbon, not fiberglass.  Should be able to reduce weight considerably.
Just a little update for everyone.
Rebuilt all the injectors and ran new fuel lines for E85. (have 1260cc lucas injectors for when my ECU comes in from Stinger)
In the process of replacing clutch to the stage 3+ SPEC but am having trouble removing the Pilot Bearing.  I will probably be able to get the thing off today.
Put a fresh gasket on the oil pan, which will hopefully fix my oil leak.
Cleaned like 30 pounds of old oil dirt and grease off the bottom of my car... lol
Next mods after this.
Sway bars
CHE Control Arms all around
Chuck's Motor Mounts
Custom Gauges (probably autometer)
Clean up dash
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Got my clutch in, and cleaned up everything!  I can't really go to hard on it, because I am going to obey the 500 mile break in rule for the new clutch.  I still have an oil leak, but I suspect that it's the valve cover.  From what I read online it seems the ranger valve cover is the way to go.
I am at work, but I will post pics of the progress soon!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Quote from: Carl;355812
We've made A LOT of progress on the race prep.  99% of the sound deadening / caulking material is gone.  I uploaded a new episode on youtube!  Sorry about the quality... it got screwed up in processing. http://www.youtube.com/watch?v=fofIfR4vAG0
alright! that's what i'm talking about.. pennywise! hahah
Carl's Road Racer
Yeah man, gotta love punk rock.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Quote from: Carl;368349
I'm going to say you mean valve cover gasket, not the valve cover because I think the ranger valve covers are stamped steel instead of the cast aluminum ours are.  The ranger gasket is worth the extra money!
Carl's Road Racer
Quote from: fordguy545;368414
Yup I meant the gasket :hick:
Good to know!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Carl's Road Racer
Ok, so... I may have been overboosting my ihi for the past 6 mos.. I found out the stock boost gauge is garbage. Turned my boost down to 16 and am slowly inching it up to a correct 18. The good news is the turbo took no damage at all. My car is wayy faster than its ever been now!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
