Topic: power steering pump (Read 1319 times) previous topic - next topic
power steering pump
anybody know how to make the power steering pump on a 5.0 shut up. it gets annoying sometimes. it has 220xxx on it any advise?
power steering pump
while its running take a wire brush to the underside (side that touches the pulley) of your belt to rule out that it is the belt and not the pump.
power steering pump
belt is only 2 months old its done this for years its a whining noise
power steering pump
Typically they whine for one of two reasons.  They get low on fluid or there are metal flakes in the fluid.  I usually just replace the pump if it got low on fluid.  If there are metal flakes in the fluid it can only come from two places, the pump and/or the rack.  Does the whole steering assembly have 220,XXX miles on it?  If so its probably time to say your got your money's worth and put a little TLC and a few $$$ back into the car.  There are a couple of threads here with some really good ideas on servicing the front end on these cars.
http://www.foxtbirdcougarforums.com/showthread.php?29909
http://www.foxtbirdcougarforums.com/showthread.php?30351
You may also want to look at the control arm bushings and ball joints, sway bar mount bushings, sway bar end links, and the outer tie-rods.  All of this with that kind of mileage needs to be thoroughly inspected.
Darren
power steering pump
Mine does the same thing. I added the stop leak fluid and it did make it a little better.  Not too much though. I just deal with it, it makes more noise when it's cold out.
power steering pump
Put in ATF instead of PS fluid. The manual actually calls for MERCON instead of PS. I put it in mine, quiet as a mouse. Replacing everything definitely can't hurt though.
