Topic: Engine Upgrade Help (Read 1292 times) previous topic - next topic
Engine Upgrade Help
So, what started as simply doing the head gasket has now expanded to me wanting to basically rebuild the entire top end of my 'Bird. SO: I'm putting on a 4bbl intake and carb from an '85 Mustang and will be doing a valve-grind job, but now I kind of want to go whole hog and do the timing chain. And so I figure if I'm doing that I might as well throw in a cam, and if I'm doing that I might as well throw in new lifters and so on...What I was hoping for was for some insight into what I should look for in terms of cam grinds/brands/lifters, etc. I would like to know what you guys/gals have done.
Engine Upgrade Help
What do you plan to with the car? Daily driving/cruising/occasional fun car?
Track only? Drag? Autocross?
How much do want to spend?
and what engine are you starting with?
Engine Upgrade Help
What year is your car? If its an 85 or newer, see if your hydralic roller or not. For the best bang for the buck, stock H.O. cam, and lifters.
Engine Upgrade Help
My 'Bird is my daily driver, but I want a car that I can shamelessly take to the strip on a High School Drag day, or street legals night but also be able to have a relatively uniform power curve where if I will have at least a decent Autocross car. Sounds complicated I know but I think you'll understand; I just want more performance that doesn't hamstring me into one particular type of motorsport. My 'Bird is and '83 and I KNOW that it is NOT rollerized...and to keep the costs down I don't really want to go to a roller cam.
Engine Upgrade Help
Well, if it were me, I'd find an HO short block, throw on at least some GT40 heads, preferably some TFS heads, and decent 4bbl intake/carb combo, some bbk shorties, and while you have the engine out, change to a higher stall torque converter, and throw an o/r h pipe and 2.5" exhaust on. I'd also change the gearing and put at least 11" front brakes on.
I dunno what your budget is, but that's pretty close to what I'd do with an older Fox, money allowing. Hope this gives you an idea...of course, you can make more power with more money, just depends on what you have to spend. Also, with it a daily driver, there comes a point where things become akin to using a broadsword to butter toast, if you will.
There's no way I could (or would even try) to drive an 8mpg hotted-up Tbird to work 5 days a week, for example.
Engine Upgrade Help
If you're not planing on pulling the short-block I would run a mild cam because you will not be able to install a stall converter without pulling it or the tranny. If it were me and I was in your situation I would get something like the Edelbrock performer power package. It makes good power from idle to 5500 rpm. It includes the intake, carb, and cam & lifters for $601 from Jegs. It's a matched kit so there is no guessing. Sound like a  Edelbrock commercial. But know BS, me and a freind installed this kit on a 67 bronco and it run very good for the money and worked well with the stock stall.
Engine Upgrade Help
Save your money and just get a cam that 2 steps over stock. Speed-pro or something cheap that will do.
Your better off spending money on upgrading Brakes, Rearend, Suspension, tranny before you go for power so just do what you need and leave it for now.
Things to upgrade as you go along.
Being a 83 T bird odds are you have 7.5 rear with open dif. So drag racing you will not be happy doing one wheel burn out and tire fire around conners in Autocross.
Get 8.8 from a TC and get disks out back and upgrade the front brakes as well.
Tranny will not be to happy with you as well. Trans Cooler, shift kit if its in good shape will help alot.
You still have Suspension to look at.
Frame Connectors will help too.
The list can go on and on.
Autocross tires or stock?
If this was up to me i would just drive the car and work on your driving skill.
A good driver in a slow car can beat a fast car with a poor driver.
