Topic: 4 bbl. Intake and Carb (Read 3818 times) previous topic - next topic
I elected to wait to do my head gaskets until I could find the money to also install a 4 bbl intake and carb. As such I found a guy who is selling me the stock intake a carb from an '85 Mustang GT. As far as I know the carb is the factory carb. So I'm wondering if anybody has any useful tips on how to modify the Automatic Kickdown so as to work on the "new" carb. I know that if say you buy a carb from Edelbrock or Holley you have to buy a Lokar adapter bracket but I'm not 100% sure if I need it for a factory Ford piece. The guy says that the carb was from a manual transmission Mustang. ($100 for the intake and carb seemed pretty decent to me)
I would find a kickdown for the carbed motor
Since it is a Holley carb I would assume that you could just call Holley and get the parts for the kick down if they are in fact missing.  I know the direct replacement carb from Holley is a part number 0-80457 and it comes with all the necessary hardware for the kick down.
Darren
Quote from: Hutch;348547
I am guessing this is a Canadian car that has a 2 bbl carb and an AOD?
Maybe you can adapt your existing TV cable to the 4bbl carb.
In any case you will want to search on here for the TV adjustment procedure so you don't damage your AOD.
Quote from: softtouch;348590
So did Canadian T-Birds come with the 2 bbl stock? I had thought that the fact that the TBI system was gone in favour of a true carb meant that the engine had been rebuilt. Yes it is a Canadian 'Bird.
It doesn't look like it would be that hard to make...
Quote from: Hutch;348697
Yes 83 & 84's built for Canada came with carbs. Not sure about 85's.
Quote from: softtouch;348711
That's actually pretty cool to know thanks.
Do I need to upgrade my stock mechanical fuel pump?
Quote from: Hutch;350693
Not for a fairly stock motor. Thats alway something that can be upgraded later.
Go here and read under "Fuel Requirements".  From there you should be able to calculate how much fuel your fuel pump needs to be supplying.  I thought that was some good tech data and I saved the article.
http://www.holley.com/data/Products/Technical/Fuel%20Pump%20Tech%20Info.pdf
Darren
Quote from: Aerocoupe;350754
Darren
Nice link.
Hey did you guys find a fix for this? Ive just run into the same issue. I put a new holley and a new edlebrock on the car, and with them, the kickdown lever has the spring almost maxed out, probably not the ideal place. since then Ive discovered my air cleaner doesnt fit. she's too wide, leans on the distributor. so ive gone and grabbed a 1" spacer plate. and now the linkage doesnt even go that far. any suggestions on an extender of sorts for it? ive got pictures of my conundrum if you need them.
Not sure if we are talking about a kickdown cable or rod hear, but this is what I used when I went from a v-6 2 bbl to a 302 holley 4 bbl
on my 83 Bird.
my kickdown ROD was to short and this fixed the problem for me.
http://www.summitracing.com/parts/HLY-20-41/
