Topic: 3.8 and 5.0 aod's???? are they the same??? (Read 8560 times) previous topic - next topic
I was looking at my 3.8 auto bird and it kinda looks like it shares the same aod as a 5.0. Is right or an optical illusion. Ive never messed with 3.8's before so i need some learning.
1999 Trailblazer(wifes rig)
Externally the same. Internally different. At least they where different in 84.
Here are the specs from the 84 shop manual.
the bellhousings are the same? never knew that
Quote from: turbo_88_XR7;342453
yup
good to know.. not that i ever use AOD's LOL
They're good for holding heavy doors open, or closed. Haven't found any other worthwhile reason for having them around though lol
couldve sworn the only internal differences between fox 5.0 and 3.8 AODs are a few extra clutches.
Quote from: ThunderbirdSport302;342474
The one in my car seems to be fine so far. knock on wood....
they suck when you throw performance parts at the motor without modifying the trans.. they're nothing compared to a C4/6 in my opinion.. the only upside i see is overdrive for people who care about gas mileage.. which, i am definitely not 1 of lol i prefer power over gas mileage anyday.. if i wanted gas mileage, i'd buy a hybrid and that'll never happen in a million years lmao
If I ever get another Thunderbird, it'll keep the AOD, but it'll get beefed up some...
Then again, a T5 with issues has kind've gotten on my last  nerve. I plan on putting more power under the hood by spring, and an already weak, "entry level" manual has got me wanting more....will the Sport have an enhanced AOD for next summer....or something with a clutch, and 5 stronger gears? Hmmm.
Eric's writeup says you can actually use your 3.8 auto if you were to swap in a 5.0, but obviously it wouldn't live very long.
-'88 Tbird 3.8
-2012 Altima 2.5 BASE.
Future: Budget 5.0 300 HP.
yes and that works in reverse too.
If you want to pull a 5.0 trans to replace your burnt up 3.8 trans, go for it. its all good.
Cool!!! So I have a 302 laying around somewhat stock? If i get some 5.0 bird mounts to install it. I could bolt it up to the aod until it goes poof!!! Most likely why aods go bad is because of that  t/v cable adjustment!!
Quote from: turbo_88_XR7;342484
Have you driven a car with a built AOD? They are pretty fun ;)
