Topic: 3.8 and 5.0 aod's???? are they the same??? (Read 8586 times) previous topic - next topic
Quote from: 93customcougar;348545
i'm doing the same swap,, and if i use the steel bar off a f150,, that comes from the carb to trans clutch will it work,, or will i still have the same problem,,, it a 93 xr7 3.8 stock modified to a 69 302 carbed motor
Your best bet would be to use a lokar cable set up, that way you know you can adjust it to what you need.
Quote from: jcassity;348530
60 deg motors for both.. the 3.8 and 5.0
not sure why anyone would think the bell housings would be different.
actually the AOD 3.8L supercharged cars is the AOD go get.
Im done shifting.
The c4/c6 comment,,, well then have yourself an AOD with O/D and just down shift one detent,,lol
If you're referring to the angle of the "v", then you're wrong, both the 3.8 and the 5.0 are 90* engines...;)
Still available if someone really wants it.
http://www.foxtbirdcougarforums.com/showthread.php?19763-500-Hp-Aod
