Topic: Weight Reduction (Read 4708 times) previous topic - next topic
Weight Reduction
Since the white bird is slated to be a Pikes Peak hillclimb car (2WD Time Attack Class) I am wondering how much weight I can expect to shed from a simple "Stage I" gutting of the interior. Panels / Carpet / Seats / Dash / etc...
"Stage II" will involve replacing the windows (removing power window ) and getting a full fiberglass front clip, (hood / fenders / front end) trunk lid, and fuel cell.
"Stage III" Lighter drive shaft / Flywheel / Wheels
Here is what I am guessing
Stage I = 300lbs +/-
Stage II = 350 to 400lbs +/-
Stage III = 25 to 50lbs +/-
Total race weight goal = 2500 to 2800 lbs +/-
Any other suggestions from those who have actually done this are appreciated!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Weight Reduction
se out the sound deadening  that at least 20 lbs, the bumper reinforcements and the impact shocks are good for another 75 lbs
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Weight Reduction
Wow, that's alot of dead weight!
Thanks!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Weight Reduction
Quote from: turbo_88_XR7;337945
what is it? TC, 5.0?
It's a turbo coupe.
I gave up on the 5.0 scene after I got my first 2.3t haha :burnout:
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Weight Reduction
After I sed the sound dampening material off the backside of a stock carpet, I put it all in a garbage bag then weighed it at roughly 40pounds!
The Carpeting itself only weighs about 8 pounds now. ;)
That was a 4eye interior though, Dunno about 87-88 Carpeting.
Weight Reduction
ah.. i was going to say try finding some aluminum heads because that'd save you quite a bit of weight lol
Weight Reduction
if its not gonna see street duty, pull the impact beams out of the doors too.
also, i would swap stgII and stgIII around. rotating weight is more important than sprung weight. i.e. do the "free" weight removal, then when it comes time to spend money on getting lighter, spend it on rotating mass first.
Weight Reduction
Do a side exit exhaust with no lers... lol.
Weight Reduction
If you want to be competitive, go all out. I think that if you went with a aluminum headed 5.0 you could be faster for less, but since you already have the 2.3 do it.
I would pull everything. You can put it all back if you want to street drive it again.
Weight Reduction
just the sound deadener glued to the floor came out to 38# in the 87 lx(?) I have.  Carpet itself was 40#.  I'm going through the same stuff right now trying to loose weight for autox instead though.  2800# should be pretty easy I think.
Weight Reduction
it's a shame i don't live out closer to you.. i'd love to set my GoProHD in car camera up and catch an in-car video :D my life long dream is to run pikes peak, even if i have to do it in a yugo hahah
Weight Reduction
When would this take place? I'm not exactly close, but I would love to see a pikes peak and fellow cougar owner.
Weight Reduction
Wow, I didn't think the sound deadener would add up to that much.  I thought about sing it off but got lazy when I thought about how much there is.  I may just have to get to it.  I have some weight reduction done : 2.3T in place of 5.0, removed carpet and padding, all interior panels, deleted heater and ac, removed all ducting and excess stuff from behind dash, removed rear seats and installed manual seat tracks on the front, and a few things in the engine bay.  I haven't weighed it yet but I am hoping it weighs in around 3000.
Weight Reduction
Quote from: Haystack;338088
The hillclimb takes place in July of every year. Although, I am not sure if I will have the car ready by next year. Also, I have to start doing autox / other racing events to get good at driving. I don't want to drive off a cliff LOL
Pikes Peak will be fully paved by 2012 I think it is. At that point, the competition should get VERY intense.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
