Topic: Weight Reduction (Read 4726 times) previous topic - next topic
Weight Reduction
Quote from: carl;338097
pikes peak will be fully paved by 2012
BOOOOOO!!!!!!! not cool :mad:
Weight Reduction
Quote from: turbo_88_XR7;338098
Yeah I know...
welp if you want to attend an older and more local race check this out
NO GUARD RAILS AT ALL
I am from Vermont btw, so I will probably be attending this east coast hill climb :]
http://vtcar.com/2010-09-14/2572/
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Weight Reduction
Quote from: bhazard;338007
Do a side exit exhaust with no lers... lol.
It's going to have the stinger 3 inch, but it's going to be a straight pipe. Anyone know of a sturdy driveshaft to maker?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Weight Reduction
check your local transmission shops.. you'd be surprised what kind of stuff they can make
Weight Reduction
Quote from: Carl;338099
Yeah I know...
man i wish my buddy josh still has his GTI :( i'd do that in a heartbeat
Weight Reduction
Backseat, passenger seat, all carpet and padding, all the glued down soundproofing in the interior AS WELL AS the trunk.  Take out every stich of molded plastic interior trim as well save for the dash.
FWIW -- I'd leave the side impact beams.  More weight to be shaved by removing the power window motors and door lock actuators.
Take out ALL the glass and window trim.  ALL OF IT.
In short -- strip it as if you were going to part it out, but leave the drivetrain, dash, column, wheel, and driver seat along with the sheetmetal.
Weight Reduction
i say ditch the dash too, if it's just a toy.. a nice aluminum dash will save you a few pounds and give it that sinister race car look ;)
Weight Reduction
Quote from: V8Demon;338143
Yeah I think I will leave the stock dash, should save me a lot of time in the long run. :bowdown:
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Weight Reduction
Good luck on the 2800lbs
 I've gutted my Blk car out pretty well :Door beams,sound deadning,trunk sheet metal
light weight seats  and it weights #3200lbs with me in it.
Weight Reduction
My car weighs just over 2900lbs(w/out my fat butt) I have 2 amps, 1 10" sub, and full interior, it can be done, I think you could see 2600-2800lbs with the right stripping. don't wreck your car or it will fold in half. lol
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Weight Reduction
Try removing the bumpers and cutting out all the center junk if you have access to cutting torches.
All you really need is enough meat to hold up the bumper covers and support the mounts right???  LOL
1986 Thunderbird:  5.0L (157,000km) /AOD/ 7.5  Accel Cap/Rotor/8mm wires.
Wanted:
-10 Hole rims or turbines
-Stock K-member or cheap aftermarket
-Cheap  8.8 posi  Rear.
R.I.P
'84 Cougar  3.8L 4BBL / AOD/ 8.8 posi  "Runns"
'93 Mustang 2.3L /T-5/ 7.5
'85 Cougar 3.8L /AOD/7.5  "Jolly Green"
'87 Mustang 2.3L / T-5/ 7.5
:burnout:
Weight Reduction
Quote from: 347Thunder;338262
4eyes seem to weigh less and seem to do better with reductions than 87-88's, Maybe its just me. :dunno:
Weight Reduction
oh, yeah I forgot what year he was doing
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Weight Reduction
X2 on the 4 eyes. I firmly believe there is a couple hundred pounds, even stock compared to the later years.
Weight Reduction
Quote from: 5.8fastcat;338226
i would have guessed the blkcat was lighter than that. my TC is 3199 with half tank of gas, no driver. it still has door beams and a full interior minus the loose sound material.
i think 2800 is doable with a race car type of gutting. no glass, no interior, no extra wiring, no stock crash parts, etc.
