Topic: Parting my '88 Sport in the weeks to come...PICS ADDED 9/26!!! (Read 3403 times) previous topic - next topic
Well, I just bought a Crown Vic, so I'm going to be parting out the 'Bird.
No pictures as of yet, will be adding pics in the upcoming weeks.  The car is still completely assembled and running, I'm going to strip it down in the next couple weeks.  Here's a list of some things, feel free to ask about any other items.  EVERYTHING IS ...OR BEST OFFER!
Rebuilt T-5Z(2.95 1st gear) with less than 1,500mi, including BBK adj clutch cable, billet aluminum quadrant, pedal assembly, bell housing, clutch fork, Zoom stage 3 clutch, FRPP billet steel flywheel (28oz), Hurst shifter and your choice of speedo gears(maroon-3.08, black-3.55, or red-3.73), will include crossmember and poly trans mount if needed.
Asking $1,100/OBO just a starting point, make me an offer, I have all warranty info and receipt.
11" front brake conversion with rotors, bearings, spindles, calipers, hoses, newer mustang struts and newer strut mounts...about 60% pad life.
Asking $200/OBO
15" 10-hole SSP black replica wheels, not perfect but nice.  Has 225/60R16 Fuzion HRi's on them, less than a year old, new they're @11/32", now at 10/32". Less than 2500mi.
Asking $300/OBO
buttstuffog cluster reading 18x,xxx miles
Asking $50/OBO
Dash trim(brushed stainless look) with custom gauge panel that replaces clock/passenger vent register....custom made from fiberglass, mounts two 2 1/16" gauges, black wrinkle finish, uses factory clock mounting location/hardware.
Asking $100, or $40 for just the gauge panel
ChuckW's poly mounts
Asking $50 sale pending
other interior parts available, tail-lights and headlights and Turbo Coupe/Sport rear sway bar.  If you want anything not listed...ask!
I'm also open to trades...I'm looking for 16" police wheels with centercaps, an aftermarket lock-up convertor for an AOD, aluminum CV or GM driveshaft.  Maybe even a SuperCoupe AOD, AODE or aftermarket AOD.
Parts located in Aiken, SC 29803
Thanks,
Don
What color is the interior?
Grey/blue interior.
I need the a/c harness that goes from the compressor to the driver side fender.How are the door panels? Can you post some interior pics?
Pm also sent. I'll be off for a while,but back later tonight.
I'm interested in the Chuck W Motor Mounts.  Are they fairly new?  Any pics?
Quote from: The Shredder;336137
Even if they aren't fairly new, it won't matter. Pull the dampeners out, soak the metal in some cleaner, spray off the dampeners, put back together, and away you go. I picked up spare dampeners of different strengths but so far so good - I think at 2 years now and no noticeable aging of them.
Good mounts, that's for sure, and gives me clearance where I had to dent my headers with the stock mounts - even after grinding the stock mounts to limits that probably damaged the mount safety bar structurally.
1988 Thunderbird Sport
I'd pick up the springs, the taillights, and the front inner marker lights.
I'd get the poly mounts too if they're not already spoken for.
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
Are you selling the body?
ChuckW's mounts are pending sale.  The door panels are grey, not great...I'll get some pics this weekend hopefully.
I would sell the body, if you want a slightly rusted northern car.  It won't even be a rolling chassis.
I'm going to work on pics this weekend.
Wheels...
That pic looks like a cop Thunderbird.
Good doing business with you.
I'm stripping the car currently, so pictures of some stuff should be available tonight or tomorrow at the latest.
thanks,
Don
Pics!!!!
Clean Mercon being drained from trans...
5 speed swap parts with T5Z.  Clutch cable, shift lever, shift , pedal assembly and console bezel/shift boot included but not shown.
Zoom clutch...it's purple, but looks kinda blue in pics
BBK clutch cable is about 6 1/2 months old, no fraying on top where they usually break...
buttstuffog cluster
Guage panel
Door panels
More pics!!!!
Wheels/tires
I have pics of all the warranty documentation for the transmission and I can get a pic of the receipt to serious buyers.
Are the front seat belts blue?  I'm needing ones that are not all cracked and broken (sleeves, if nothing else).
Thx!
'87 Cougar LS V6 (stock) Daily Driver
'06 Lincoln LS V8
'12 F-150 SCrew FX4 5.0L
'80 Thunderbird V8 (mild 304) [sold to friend]
