Topic: gear/diff swap (Read 9884 times) previous topic - next topic
gear/diff swap
Reply #45
everything after the "..." is coming soon....
the car is running good as is SD...i'm going to do the heads, intake, TB, and MAF at the same time...because i know at that point my vacuum signal would be beyond screwed up which is why people say you cant run an aftermarket cam in a SD engine...
86 Mustang GT
gear/diff swap
Reply #46
With a B cam the vacuum signal is already shot in the @$$...it may SEEM to run good.  I can assure you though, if you had a wideband O2 on it, you'd see that it is not.
Good luck,
Don
gear/diff swap
Reply #47
i was once told that the B303 is better suited for a manual car.. true or were they blowing smoke up my :shakeass:?
gear/diff swap
Reply #48
i do have a 5 speed in my car....
86 Mustang GT
gear/diff swap
Reply #49
i'm just asking a general question, because it's something i've heard a few times from different people
gear/diff swap
Reply #50
The B-cam is better suited to a 5-speed...in a MAF car.  It's down on low speed torque when compared to the E-cam...a lot of people just look at advertised duration and lift, but if I remember correctly, they have different LSA's, which will make a huge difference.
gear/diff swap
Reply #51
that's what i thought, good to know it's solid info
gear/diff swap
Reply #52
I think that, according to all of Dougy's posts, his seat-of-the-pants dyno needs to be recalibrated...regularly.
Good luck!
-Don
gear/diff swap
Reply #53
Quote from: Sick88Tbird;337657
I think that, according to all of Dougy's posts, his seat-of-the-pants needs to be recalibrated by a steel-toed boot regularly.
Fixed, :evilgrin::rollin::D
