Topic: Trying to tune to ECU for more boost (Read 8169 times) previous topic - next topic
I am wanting to turn the boost up on my IHI to 17 psi and was wondering how I can safely turn up the fuel pressure as well. Who makes the best chip for the 87 turbo coupe ecu?
Thanks
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
http://www.moates.net
The BURN1+F2A+F2E chip setup is basic, the Quarterhorse is better with real-time adjustability and data-logging.
Good luck!  A whole new world to learn.
But remember, the fuel pressure can be adjusted by getting an aftermarket AFPR.  And the boost can be up'ed with a Boost valve.
or you could go megasquirt for tuning!  No more VAM.  I'm pushing 30psi to mine out of a holset now.
ok looks like i'm going with megasquirt
i found this website http://www.diyautotune.com/tech_articles/megasquirting_your_ford_with_the_MegaEFI_EEC-IV_adapter.htm and am looking over things
can you tell me exactly what I need for my tbird?
THANKS!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
go to  Turboford, there is a guy that builds them for the TCs.....
The only prob is... I am at 7,000ft up here. I would have to have it tuned up here with someone willing to do it. I am a novice when it comes to that unfortunately.
Would it be safe for me to turn my boost up to 18 on the stock ecu setting with a walbro 255? (which I have installed)
Just wondering
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Wait what are you guys talking about? He's wanting to run higher boost on his stock TC.  All that takes is a mbc. Maybe an upgraded pump if its weak.
Quote from: bhazard;336898
I'll just add that alot of guys get an AFPR and up the fuel pressure just a bit to account for the extra boost.
The Ric Gillis Boost Valve is usually a good way to go. -> http://www.boostvalve.com/
You said you already installed the walbro, so the "HARD" part is already done.
You might want to keep an eye on your air/fuel ratio, but you should be more than ok.
There is a graph/formula around on one of these sites that tells you how much fuel pressure you are suppose to have, for the amount of boost you are running. If I find it again I'll post it here.
This right here should be really helpful for you right now. -> http://www.turbotbird.com/techinfo/Mods/Mods01.htm It basically stats the some of the very first and basic mods that most people do to their T-Birds.
...and there was light!
no need to do anything with fuel pressure, it will or should increase with the boost....
 1 psi of boost = 1 psi of fuel
I already have a gillis valve lol. The only reason I am afraid to turn the boost up is because they were afraid to at the dyno shop... (for some reason???)
OK.. in that case, I will turn the boost up and get an AFR gauge tomorrow :burnout:
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Narrowband afr gauges are a waste of money. Don't bother.
Quote from: bhazard;337023
Meh, it's just a precaution. Only 30 bucks. I got a bigger O2 sensor because I think the other one was bad. (Might explain the weird readings on the dyno???) Anyway, I am putting on the new O2 sensor and AFR tomorrow. Any suggestions for widebands?
Running 15 psi right now (cautiously) and will up to 18 tomorrow.
I dyno'd at 140 RWHP at 10psi (at 7000ft mind you 25% HP loss up here)
Upgrades since then...
-New motorcraft plugs, wires, cap and rotor gapped at .32
-Magnaflow straight-through exhaust (had S turn  on it)
-MSD Streetfire Coil
-Homemade Cold Air Intake (a tutorial will follow on how I made that)
-Seafoam, New Fuel Filter, Oil Change
-New O2 Sensor
I will pull another dyno run at 18 psi and tell everyone how it went. Hopefully I can break 210 RWHP.
Next stage will include
-Meth Injection (Snow Performance)
-9LB Flywheel
-Stage 2+ Clutch
-Wideband
Aiming for 300 RWHP
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Quote from: Carl;337118
AEM, Auto Meter, Innovate or FAST are really the only 1's i recommend to my customers.. there are cheap imitations out there that aren't worth their weight in s
Ive heard nothing but good things about these guys
http://14point7.com/
Quote from: bhazard;337158
never heard of them, but their stuff looks pretty good. i like the fact that it's a clear, digital reading
