Topic: Trying to tune to ECU for more boost (Read 8165 times) previous topic - next topic
Thanks for the suggestions!
btw I installed the narrowband afr gauge at 15psi it's sitting right in between ideal and rich which is great! I was afraid I was running lean.
18 PSI tomorrow. Ordering Snow performance stage II Meth Injection tomorrow also. (from summit racing)
Dyno run to follow in the near future.
I was able to beat a hemi charger today at 15 psi. From both a pull and a dig. That was highly unexpected, but I am pretty happy about it.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Why would yo run lean on stock boost?
Quote from: bhazard;337291
the shop said I was when I was on the dyno...
the only thing I can guess is that the bad O2 sensor was throwing out bogus numbers.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
I call BS. There's absolutely no reason for you to run lean on stock boost... they just want You to pay them to work on it. Ford tuned these things to run way rich. The only way to run lean really is if your pump is dying, and then it would be pretty obvious.
The o2 isn't even used under boost, so I would say that's not it..
 Chances are your car is fine.
Quote from: Carl;337581
The o2 sensor has ZERO function at WOT, if you were running lean, probably have a F/P regulator problem or other fuel system issue...
thanks for the advice! my air fuel ratio seems good at WOT so I dunno what they were talking about.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
A little update
I made 184 RWHP and 247 RWTQ on the dyno at 16psi
Turned the boost down a bit just to be safe.
For comparison a bone stock STI made 216 AWHP and 230 AWTQ right after me
You might think WHAT?! an STI reading that low?!
two reasons
at near 7000 feet altitude you take 15% or more HP loss on a boosted car 25% for N/A
also, their dyno reads low
both of those numbers are uncorrected, so I am not really sure what my actual horsepower / torque is. I would be especially happy to know what it is at sea level and at 18psi haha.
_________________________________
Now, on to my question.
I just purchased a wideband from innovative motorsports.  I want to upgrade / get rid of the VAM and was wondering what my alternatives are?
What air meters do you performance gurus use?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
A little update
two reasons
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
