Topic: The CP autox bird (Read 123566 times) previous topic - next topic
The CP autox bird
Reply #270
Quote from: 347Thunder;374774
and you need to get a k&n pre-filter so your filter doesn't get so dirty
and clean it often!
The CP autox bird
Reply #271
Not allowed to change the kmember.  If I did, they technically call it a tube chassis car and add 350# to your minimum weight.  The filter will eventually be changed.  I don't see it being a real big problem myself.
The CP autox bird
Reply #272
I will have pics of my latest endeavors with this project tomorrow.  Made a spoiler fitting the class rules(max 10" height) and made it out of 1/4" lexan(found a place up in toledo called Seeger Metals & Plastics - I would recommend them!).  I pretty much have it done, I just need to come up with some more bolts/rivets and paint the hinges.  Although I would give the longacre spoiler supports 3 out of 4 stars because the 4th one broke before I even put it on.  Stupid aluminum threads galled and I almost could've broken that thing by hand :facepalm: I'll have to order another one of those to replace it so I'm a bit annoyed about that.
I also bought a full set of koni double adjustable shocks/struts and the coilover kits for them, so hopefully I can get this car driving even better next year :thumbsup:
The CP autox bird
Reply #273
The CP autox bird
Reply #274
Holy NASCAR spoiler on roids:) will that help at the speeds your going??
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
The CP autox bird
Reply #275
people say it should make around 150# of downforce or so.
The CP autox bird
Reply #276
Wow, cool stuff. I really like those Konis!
The CP autox bird
Reply #277
Koni's are NOT CHEAP!  I have right at $2K between the konis and coilover kits.  All I can hope is they make me a bunch faster since I was using mismatched bilstiens before.  Bilstien hd's on the front and maximum motorsports sport valved bilstiens on the rear.
The CP autox bird
Reply #278
Awesome, love the spoiler!!
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
The CP autox bird
Reply #279
Finally got this spoiler completely done.  I'm having a lack of motivation this year :shrug: But I think this spoiler turned out pretty sweet!
I think I have the spoiler at about a 70* angle and hopefully will make some downforce :thumbsup:
The CP autox bird
Reply #280
Is it adjustable?
The CP autox bird
Reply #281
yeah, it can be moved some.  Not alot, but it is adjustable, lol.  It could probably come back about 1/2 way to straightening the pinstripe where its going up.
The CP autox bird
Reply #282
Wow, That definitely unique~I like it!
P.S.
I dream of being able to work on my 'Bird in a shop like that, LoL.
The CP autox bird
Reply #283
This car makes me want to cut my own face off. I'm such a failure at being a car enthusiast...
Seriously man, beautiful.
87 cougar undergoing 5.0 swap
