Topic: The CP autox bird (Read 123803 times) previous topic - next topic
The CP autox bird
Reply #135
suspension is almost all together.  I did change my mind on some things on the engine though.  I'm just going to go ahead and use the E6 manifold instead of the ATR header.  I don't have time to keep screwing with that ATR.
The CP autox bird
Reply #136
I know others who feel the same way.
It's looking great. GO! GO! GO!  LOL
The CP autox bird
Reply #137
I havent even run the ATR and it already pissed me off, lol.
The CP autox bird
Reply #138
What's wrong with the ATR?
The CP autox bird
Reply #139
PITA to get any bolts in!  And with my track record of blowing head gaskets, I don't want to deal with it.
The CP autox bird
Reply #140
You cant use studs?
The CP autox bird
Reply #141
Quote from: fordguy545;356356
That, and they tend to crack.
The CP autox bird
Reply #142
I do plan on building another header next winter anyway, so I can get by with a ported e6 for now.  I did fix the atr, but at this point I think I'm going to put it up for sale.
The CP autox bird
Reply #143
Got the engine partway there.  Got new bearings spun in, and the head on, Cam swapped out, but I need to order new lifters with modified housings so they will get oil correctly :facepalm:
The CP autox bird
Reply #144
specs on your new engine build?
The CP autox bird
Reply #145
stock w/bo 1.5 and ported e6.  thats about it at this point
The CP autox bird
Reply #146
Quote from: fordguy545;356517
What turbo are you running?
That combo screams for a T3/T04E .50 stage 3 or a Holset HX35!
I really am a fan of a fairly stock build with a little cam and those turbo's. Of course autocross might work better with less punch at boost onset from a smaller compressor wheel.
The CP autox bird
Reply #147
at this point its a stock .48 T3.  It might get a holset next winter, but at this point there just isnt enough done to the head to support the holset.  I thought about a ebay turbo with a rebuild right off the bat, but thats something that can happen later also.  I should be able to get plenty of boost right off the bat to get out of corners where my other car always struggled.  I havent been able to make heads or tails out of compressor maps so that makes figuring out turbos a little difficult.
The CP autox bird
Reply #148
Let me know how you like the cam....I have been contemplating a 1.5 for a while
The CP autox bird
Reply #149
Quote from: fordguy545;356530
You might be surprised how well that combo will do without doing any more to it. I just put valve springs and a Stinger header and got 288 HP and 322 TQ with engine management and a Porsche intercooler on pump gas.
Your turbo will work great for autocross. Mine was to laggy for that. Good at the drags, though!
