Topic: Question about SO 5.0 pistons. (Read 3176 times) previous topic - next topic
Newbie here,Are the factory SO 5.0 flattop pistons forged or cast?
Cast.....  Welcome
Welcome , what he said ^^^^^^
Also, factory SO pistons are NOT flat-tops...they have a considerable dish.
Thanks guys,i've come across a complete 88 T-bird 5.0 from a wreck with 28k miles for $250. It runs great,i just didn't know about the pistons and how much abuse they could handle. What's the compression with that dish with E7 heads? I've got a bunch of old stock mustang engine parts,STD HO pistons,cams,etc collecting dust and was just wantng to know what was the same or diffrent.Thanks for all the info again,Great site! keep it up!
With that little mileage, I'd say leave the SO pistons in it for now.  With the E6's compression was around 8.7-8.8:1 but the E7's have a little smaller chamber.  Figure around 8.9-9.0:1 with E7's....unless you send them to the machine shop and take .030" off.  Then you should be close to 9.3-9.5:1 depending on head gasket.
If you're going to run anything more than an HO cam, the SO pistons will NOT work...not sure about some of the alphabet cams, but the HO cam will work with SO pistons.
Also, as an option, you can have them fly-cut, but for the trouble and cost, HO pistons would be better, plus you already have 'em...
Quote from: Sick88Tbird;332857
The dish is 2.5 cc.
Quote from: ThunderbirdSport302;333530
Depending on what heads are being utilized; this may not be true.
You'll never know 100% for sure unless you measure PTV clearance.
Example: Trick Flows TW heads, flat tops, no valve reliefs, .565" lift and roughly 225 degrees duration @ .050" lift....  LOTS of clearance.....
Quote from: V8Demon;333548
The dish is 2.5 cc.
You should go to the CoolCats.net and read about the H.O. conversion it will probably answer a lot of your questions.
The dish is 2.5 cc.
Right, I forgot to put that in my other post...better to err on the side of caution any which way. :D
i'm running a B303 cam with stock flattops and stock e6 heads so thats another one that clears...
86 Mustang GT
The factory E6 heads have their valves recessed much further into the head than E7's or other factory Ford heads.
A local machinist told me he prefers the e6 turbo swirl design chambers to the e7's. He basically said the e7's are junk and everyone gets too caught up with flow numbers of cylinder heads in general. If you know what to do, the e6's could be made to out perform the e7's in his opinion with the better combustion chamber design.
Right, because E6's flow better and make more power than E7's is why Ford switched in 1987 on trucks, Stangs, and Mark VII's. :rolleyes:
Hey, if E6's are so darn good, I've got a set (or 3) I'll sell for an all time low price of just 79.99 each! :hick:
Somewhere online is a flow chart of E5, E6, E7 and later 5.0 heads....E6 actually do flow worse than any other 5.0 head made since '69 or so. Proven.
Of course, I see in your sig you have a paxton on yours, with a little air pressure i suspect there's not a hell of a lot of difference.
Take a stock '87-'93 HO, swap stock E6 heads on, dyno it, and get back to me. ;)
torque will be down (a lot), horsepower will be sucked out of the engine, and it won't make power over 3500-4500 max.
So I will kindly disagree with your machinist, in regards to stock E6 heads being superior to stock E7's.
