Topic: Question about SO 5.0 pistons. (Read 3158 times) previous topic - next topic
I have read that the E-7 heads are where thew extra 20 HP came from when the HP rating went from 200 to 220 back in the day.I could feel the difference between the two when I swapped the E-6's for the E-7 heads ....granted,my E-7 heads were ported and had a nice valve job and better springs.
Quote from: ThunderbirdSport302;335858
Right, because E6's flow better and make more power than E7's is why Ford switched in 1987 on trucks, Stangs, and Mark VII's. :rolleyes:
Somewhere online is a flow chart of E5, E6, E7 and later 5.0 heads....E6 actually do flow worse than any other 5.0 head made since '69 or so. Proven.
torque will be down (a lot), horsepower will be sucked out of the engine, and it won't make power over 3500-4500 max.
So I will kindly disagree with your machinist, in regards to stock E6 heads being superior to stock E7's.
Ok Normally I dont  do this BUT there are some factual errors here.;)
 1. trucks never used E6 style heads
2. Mark Vii's didnt even use HO engines till very  LATE 87
3.E5s and E7s are  near identical
4. 86 5.0 was only rated at 15lbft less torque than 87 up (not "a lot") less
5. all 5.0 HO engines are rated max hp @4000 rpm factory.
6. Flow charts  really dont mean squat ..dyno results do (this is just my opinion )
7.t.birdsc was relaying a  certain machinists "opinion" on  a starting point  for head  work and  that said machinist feels he can achieve  better  results with  the high swirl chambers on the E6s
 Now with all those points being made
 here is my "opinion "
E6 and E7 heads are not much more than boat anchors compared to GT40s and the aftermarket selections out there , personally I  could not justify swapping E6 heads for E7 heads because the gains would be so minimal in relation to the effort involved in labor .
 If I am swapping heads it is going to be for WAY more than 15 lbsft and 20 HP :D
I got two sets of e7te heads laying around,roller block,cranks,roller cams,spyders,rollers,dog bones!!! pretty much worth nothing to me!!!!
So pistons ho pistons couple aods. taking up space!!!!!!
1999 Trailblazer(wifes rig)
I really would not worry too much about either head. If you shooting for power, and RPM, why shoot yourself in the foot with stock heads? I'll be new springs and hardware could make a ton more power if properly matched.
well i can tell you this much from experience.. a .540 lift cam does NOT like SO pistons LOL
