Topic: 8.8 Aluminum Differential in my Bird??? (Read 2057 times) previous topic - next topic
I found an 8.8 Aluminum Differential from a 93 Mark VIII. I also have an entire rear end from a 97 Ford Ranger with the 8.8 and 4.10's.... Looking for input, thanks guys.
1988 T-Bird. 347 Stroker, Ported & polished Pro Comp heads, C-4 with 2800 RPM Stall Converter and the rear end isn't done yet.....:flame:
So are you asking if you should try and make the swap to an IRS from the Mark VIII or go with the Ranger rear end?
From what I can remember the MN12 platform Birds and the Mark VIII's were very similar but nothing like the Fox platforms.  I don't think the IRS from the Mark VIII would not be a bolt in but an IRS from a SN95 Cobra might be easier as they will go in a Fox Mustang.
I would go here and download the spread sheet to see if that Ranger rear end will work in your car:
http://www.foxtbirdcougarforums.com/showpost.php?p=138359&postcount=12
Darren
The Ranger rear would be set up for leaf springs and wouldn't have the necessary brackets to mount your coil spring/control arm setup. The Mark VIII rear is independent, and as aerocoupe said, would not be a bolt in proposition. You'd have to fabricate an entire rear subframe.
Also the ranger rear has an offset pinion
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Thanks guys!!!!
