Topic: aod tranny question (Read 5005 times) previous topic - next topic
aod tranny question
it will be nice ince i get the tranny in, then the only thing over 2 yrs old will be the rear end, but wanting the rearend from a mark VIII. It will be there eventually:burnout:
Remember, if the women dont find you handsome, they should at least find you handy.
When all else fails, get a bigger hammer.
Chris
 93 cat rebuilt 3.8
4r70w?
would the 4r70w work in place of the AOD without swapping computers or modifying anything?-in a 93 cat
Chris
 93 cat rebuilt 3.8
aod tranny question
Noooo
aod tranny question
what i thought but read about some1 else doing it in a differnt forum, but they didnt list any details about it
Chris
 93 cat rebuilt 3.8
aod tranny question
Quote from: sarjxxx;332300
Or, pulling the 302 and transmission and putting it in the v6 car!:rollin:
Might be a little more work though:rollin:
It'd be cheaper and easier to buy a V-8 car, if one was going that route :burnout:
aod tranny question
is the 93 bird aod trans coputer controled, what about the speedomiter is it a cable or computer controled.
aod tranny question
Quote from: Dan Nelson;332892
is the 93 bird aod trans computer controlled
negative, Ghost Rider
aod tranny question
well, once i sell my truck, ill know what ill do in the meantime
Chris
 93 cat rebuilt 3.8
aod tranny question
speedo uses an electronic speed sensor not a cable, I think '85 was the switchover year for that in the cat/birds
aod tranny question
Would it be possible to install a 4r70w in saaaay... a fox or an earlier mn-12 just by pulling the computer and running the necessary wires and harnesses to the transmission, and from the speed sensor? or speedometer or whatever it gets its information from...?
I realize the trans is computer controlled, but seriously, how much could there be to it? It seems like it could be done fairly easily to me.
aod tranny question
Quote from: sarjxxx;335231
Yes it can be done ...no it is not an easy swap... I  was just reading about this swap on a different forum and personally IMHO way too much modification for the gains
aod tranny question
Hmmm, well if it can be done, my stubborn ass will definitely want to consider it:D
aod tranny question
Just so you know, you can put an AOd in there no problem.
I was talking to a SC guy today, who swithced out his 4R70W and put in a AOd. He said there was nothing he had to change to get it tin there.
So, this means to me that anything out of a thunderbird or cougar, on or before your year, will go in your car. Whether it be AOdE, or plain ol AOd.
aod tranny question
Quote from: sarjxxx;332299
depends on the car. There are different levels of torque converters in the myriad v8 cars. However, this is backwards compatible, afaik there's no reason why you can't use a v8 trans in a v6, I just wouldn't go the other way.
actually you do want the later v6 aod over the v8 trans, especially for the aod behnd the super charged v6.
aod tranny question
its not a supercharged v6, and it is an AOD-but i dont have to look no more; i ended up having it rebuilt- its in the shop right now, should get it back tommorow or tuesday
Chris
 93 cat rebuilt 3.8
