Topic: Lowering.. (did search) (Read 6263 times) previous topic - next topic
I did a search and found that SN-95 springs are a way to lower the sport birds.  Has anyone tried a set of Mach 1 or Bullit springs?  I have a set laying around and thought about putting them on..
I got Mach 1 springs all around in my 88 cougar.  I used CHE adjustable control arms in the rear to bring the height up, but the front is real low I can only fit one finger between the tire and fender.  I haven't driven it yet so I can't comment on the ride yet..
I have a set of FMS 1.5 inch drop springs for a 88 mustang I installed in my 85 TC, the front fenders now cover the tire by about 3/8 inch  and that is running a 225/50/16 tire
I have bullits on the rear, with che adjusted up. Didn't put the fronts on yet, still not sure I want to. I may go with what V8 Demon has on the fronts.
I'm using the SN-95 springs.I like the overall look,and the car can still take a speed bump without having to slow to a crawl.
Quote from: Bob;328344
Have any pictures of car with them?? I went through your build post and didnt see any...
Quote from: vinnietbird;328370
Seen you car when I did search, and thats looks good.  Thats what me got to thinking about the Mach 1 springs.. Since I already have them. If they drop it to far then will just wait to lower it.  Only reason I am considering the Mach 1's is because they are a FREEBIE.... And free is alway's in the budget..:D
Quote from: BogusSVO;328348
Thats little bit too low , for my comfort..
I'll have the car outside this weekend or maybe next weekend I take a side profile pic for you.  In the garage it's hard to take a pic of the side
Quote from: Bob;328386
Cool,,, thanks man.
I have the same as Vinnie. Of course I have no motor in.
The drop in the rear was pretty noticeable after it was done
Quote from: daminc;328391
Stock SN-95 springs??  I like the way Vinnie's set, but I already have a set of mach 1's sitting around.. But if they slam it, then not going to put them on.
They will probably sit like Bob's about 1". They also have the poundage to handle good.You may want to change the struts to mustang type. I don't think it's required though.
Mach 1 springs all around. CHE adjustable ht. rear control arms. Looks good, rides bit stiffer - wide wheels give a slight touch of the inner fender on big dips in road - nothing I can't live with.
Quote from: Cougar5.0;328701
It looks good! What che's did you go with? I see they have a couple different types. I have the FMS lowering springs on mine but the rear sagged so I tried the rears from an sn95 stang, they sagged even worse, then tried the rears from a fox stang, they brought it up a little but not enough. So I thought I'd put the rears from the FMS kit back on and get the upper adj. control arms I keep hearing about on here.
I forgot to add that I have CHE non adjustable in the rear. not sure if Vinnie did
Here you go,  I didnt get the cat outside so I took the best pic I can of the front.
Mach1 springs,strange 10 way struts, and MM caster camber plates is my setup for the front.  Rear is mach1 springs and CHE adjustable control arms.
The gap upfront is about 1 1/2 finger- almost 2 fingers wide.. keep in mind this is with a 351w based stroker so if your running a 302 block I think it will be a little higher.
