Topic: xxxx (Read 1451 times) previous topic - next topic
xxxx
xxxx
xxxx
So this goes in the empty cubby slot above the radio? got a picture of it installed with a cup in it? lol I think I want this.
xxxx
It wont fit above the radio without doing some modification to the a/c duct work
 ask me how I know :(
xxxx
How do you know? lol Isn't the duct work above the empty cubby hole?
xxxx
Its kinda above...... but where it starts to slope down to connect to the heater box it is not far enough back to fit the slide out trays .
I have one of these trays on a shelf in my garage that I was hoping to use.
 If you don't have EATC you can modify the stack and put it in the bottom slot though :D
xxxx
Hmm... My bottom slot have my HVAC controts. I would have to transfer the radio up one, the HVAC up one and this in the bottom... It might work. Why would the slide out trays be the problem, they are contained. Why would this connect to the heater box?
xxxx
The whole assembly is too deep to fit in the top slot......  and sorry I wasn't clear , where the duct work slopes to meet the heater box  is not far enough back for this tray to work . I think Daminc has done this mod on his convertible  .  I know i have seen pics of it somewhere  . anyway ...bottom line is it will not fit in the top slot :D
xxxx
you pretty much need the same room as the radio needs to make it fit. you would need to move the heater controls to the top space.
xxxx
Quote from: daminc;327619
That's where I remember the suggested location should be in the bottom slot. I forgot what location actually had the cubby because I get all confused with all the different positions I see people use. Anyway what is shown here is the best ergonomic arrangement all around with HVAC controls, then radio, then cupholder.
I feel a little silly now offering this cupholder for sale since they are a dime a dozen on numerous Ford Taruses and Mercury Sables. However I hate to discard it if someone wants it.
xxxx
Would this fit with the floor shifter and console  car? I want a cup holder, I just don't want to be able to use it.
xxxx
I suppose it would work... might hit if the car is in park. if someone could measure the distance between the shifter and dash, I could measure the extended position of the cup holder from the dash outward. I'm putting a full console in the vert myself, but not the floor shifter.
xxxx
Quote from: jpc647;327726
What? You want a cup holder you don't wanna use???:rollin:
I would say it would be functional only if the shifter was in gear.
xxxx
Sorry I made a typo. I meant I don't want to buy it and then not be able to use it. lol
Would I have to remove part of the dash to swap the heater controls? Is this a hard modification? I would only want to be able to use the cupholder when I'm driving.
And daminc, if you could get those measurements that would be awesome. I have a full console and floor shifter, I can measure the space, :)
xxxx
I just measured from the lower section, back to my floor shifter in park.  It was 3.25 inches approx.
Mike
xxxx
The cup holder extends out 5" from the dash.
