Topic: Fox body suspension?? (Read 8737 times) previous topic - next topic
I have a 84' T-Bird that I have some questions on the suspension and rear end. I have been told that the Mustang Fox body style cars are the same suspension and rear end and how they bolt up. I am looking to put a tubular K member and control arms, coil over kit etc. I have a 351w that is being built at (515hp) specs and want to be able to put the power to the ground. Does anyone have any info on parts/manufacturers on any "swap" parts for my Tbird????:burnout:
I have,
8.8 w/31 spline locker with moser axles
C4 with Boss Hog 3000 stall convert
.30 over 351w
Everything should bolt up just fine.
I got all my stuff from Team-Z but there are lots of other companies.
http://www.foxtbirdcougarforums.com/showthread.php?t=25361
Sounds like you are going to have a very nice and fast car.  I also have the same torque converter and I'm happy with it.
TED
Mustang control arms (rear) will NOT work...fronts will, however, depending on years.
THIS thread will aid you in finding what fits correctly...
Need the CHE  rear ctr arms.  The control arms on the rear are bout
1/2 to 5/8 in longer on a Cougar/Tbird than the mustangs.
 You can run them but it will pull the rear end foreward  could cause tire rubbin issues.
Quote from: 5.8fastcat;326683
The TBird uppers are even longer...1-1/8"
the lower control arms are the same on the rear for mustang and thunderbird... ( I just installed a set of mustang lowers in my 85 TC)
Chuck is right, the Tbird upper rear controll arms are longer
Quote from: BogusSVO;327462
The lowers are not the same.  The difference is small, but there is a difference.  Had them side-by-side when we built them @ Kenny Brown's and if there wasn't a difference, CHE wouldn't also have a different part for the Tbirds.
Quote from: ThunderbirdSport302;326429
What, am I talking to myself here or what...:punchballs:
I bought a set of adjustable's from UPR so I should be able to set them correctly, I hope. Thank you for the advice.
Quote from: ied_hunter05;349917
I assume you mean lowers?
Both uppers and lowers. They are the solid bushing style but are adjustable in length.  :birdsmily:
http://www.cheperformance.com/cartgenie/prodList.asp?scat=30
these are specifically made for Tbirds and Cougars, no fitment issues.:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Quote from: ied_hunter05;349953
Unless you can SAFELY adjust the uppers to over 1" longer than a stock Mustang arm they're not going to work.  I doubt there's that much adjustability in them.
You asked for information, and chose to ignore it. *shrug*
EDIT: Looking at them, they might have enough adjustment, but I'm not a UPR fan personally.
the solid mount type control arms aren't good for the torque boxes either. They'll need to be reinforced.
