Topic: Turbo Coupe exhaust (Read 10881 times) previous topic - next topic
Turbo Coupe exhaust
What's everyones setup and opinions on what's best? Mine is stock right now with stupid glasspacks, but tomorrow it's getting full three inch single from the turbo back, no cat no ler (I know it'll be loud haha) just wondering what everyone else has..
Turbo Coupe exhaust
Stinger Performance 3" to dual 2.5" Flowmaster 40's and extended mustang tail pipes http://www.stinger-performance.com
Turbo Coupe exhaust
X2. I did the Stinger 3" to 2 1/2" duals. I had that on my bird except with Magnaflow lers(FLOMASTERS SUCK!), flowmaster tail pipes and 3" x 18" chrome tail pipes. Sounded sweet.
:burnout:
Turbo Coupe exhaust
I had a 3" exhaust (no cat or ler) on my Typhoon and it wasn't loud at all. As long as you put a tailpipe all the way out the back you should be good.
Turbo Coupe exhaust
Well the best performing exhaust is going to be a 3" side exhaust. It gets the exhaust out the fastest with the least amount of bends to restrict flow. I have 2.5" to dual 2" with a high flow 3"inch cat and dual dynomax chambered lers (not sure exactly, i bought the car with it) and it sounds close to a stock 5.0. As you could imagine, thats the worst for flow.....
Let us know how it sounds! maybe a video if you can :poke:
Turbo Coupe exhaust
Quote from: quicksilver;321533
I'll post a video tomorrow after its done
Turbo Coupe exhaust
awesome. just dont get too close to the tail pipe or the sound quality will be horrible. cant wait to hear it!
Turbo Coupe exhaust
Single mandrel-bent 3", all the way back (with a tail pipe) with a straight-through ler will be MORE than sufficient for most 2.3T applications. (And by most, I mean everyone here)
No need to leave off lers for the assumed power gain and have a tedious-sounding car.
Put a ler on it...
Turbo Coupe exhaust
I have a full 3" (stinger setup) with a magnaflow and I couldnt imagine anything better.
Turbo Coupe exhaust
the best lers to get for best performance(especially if your thinking about a turbo upgrade) are the flow through type lers like the dynomax race bullet. http://www.dynomax.com/lers.php?ler=racebullet
Turbo Coupe exhaust
and it will probably sound better with a ler too... ive heard these cars straight pipes before and its a cross between a tractor and ricer.
Turbo Coupe exhaust
Well i ended up just doing 21/2 inch single instead, tried it with no ler and it was waaaay to loud haha so we threw a glasspack on it to quiet it down. Here's a vid
http://www.youtube.com/watch?v=EQ7-pphuFXQ
Turbo Coupe exhaust
yeah, i wasnt thinking a 3" was going to fit because it didnt on my friends car but i had my fingers crossed for ya. i'll check the video out  when i get home. do you like it? because thats all that matters.
Turbo Coupe exhaust
full 3" on mine; side exit with three sprint car lers.
looks like this:
sounds like this:
Turbo Coupe exhaust
Quote from: SR71blackbird;321616
3" will fit, my brother had it on his. We just didn't have enough 3" pipe so that's why we went with the 2 1/2, I like it i thinks it sounds good for a four banger haha (i'm used to my mustang) the turbo whistle out the exhaust is definetly and addicting sound :D
