Topic: tranny swap (Read 4302 times) previous topic - next topic
tranny swap
Quote from: TurboCoupe50;321381
When you talk Top Loader four speeds, a 2.32 1st gear is the close ratio, the wide ratios have a 2.78 1st...
Ah, another era...  Showing our age on that one Tom!
It seems silly in that context to refer to a Z-spec as a close ratio.
Remember the big rear gears needed to get those cars off the line?  A 2.32 first gear and a 4.51 rear is the equivalent to 2.95 first gear and 3.55 rear gear.  Man, they used to scream on the highway with no overdrive.  Their strong point was taking loads of torque!
In comparison to the T5 4 cylinder first gear of 3.97 and the standard V8 of 3.35, a 2.95 of the Z spec is the nearest thing to a close ratio box in this era, that is, without going to a custom gear set.
Of course my comments don't help the OP address the issue of upgrading his trans.  I'll bow out, I know nothing of 4 cylinder transmissions.
tranny swap
so running the Z-spec with 3:55 gears out back what would the final ratio be then? i do a good amount of free way driving and right now at 70mph my engine is close to 3000rpm. And what if my car makes more then the 330ftlbs of torque when using the Z-spec?
so im going to need a new clutch cable, a different brake booster, adjustable firewall, the bell housing adapter, clutch, flywheel. is there anything else id need?
btw, you guys know alot. thank you for your help.
tranny swap
Quote from: SR71blackbird;321445
You're having a Hellva dream... :rollin:
Use the chart to find out what gear ratio you'll have with each tranny, as I stated prior current tranny should have a 3.97 1st gear... Just multiply each gear times 3.55...
http://www.fordmuscle.com/archives/2000/09/t5swap/index2.shtml
You could maybe live with a production 5.0 tranny with a 3.35 1st gear(and those are stronger than the 4 cyl boxes), but again the input pilot will need some machine work... The .68 5th gear would noticeably reduce highway RPMs
Quote from: 86T-bird;321436
LOL
Yeah you ain't lived till you've cruised a big block at 70mph with 4.56 cogs and no overdrive(can you say 8 MPG & 4K RPMs?), even the 3.50 rear in my Fairlane about drove me nuts till I swapped it to a 3.00... It also has the 2.32 1st gear Top Loader, so even with the 428 it's a dog till she gets rolling...
tranny swap
nothing wrong with dreaming:mullet: thank you for the help, ill check that out
tranny swap
In the mean while, is there away to get the 2.3 trannys to stop rattling? mine and my friends both do it so we think its the same in all other 2.3 trannys. is that true?
tranny swap
Quote from: Aerocoupe;321322
Is there a pilot bearing which will allow the use of the 5.0L T-5 behind the 2.3L?  I know there is one to put the 2.3L T-5 behind a 5.0L or 5.8L.  Not quite sure why a person would want to do that as I would think the 2.3L T-5 would die a painful death behind a mild 5.0L.  I do not know the ID of the pilot bearing hole in the 2.3L crank versus the ID of the tip of 5.0L T-5 input shaft so that may be the issue all in itself.
Its not really that big of a deal to have the input shaft machined down as the T-5's are super easy to tear down to get the input shaft out.  You can get the manual for them here:
http://www.ttcautomotive.com/English/media/pdfs_autogen/T-5_Service_Manual.pdf
Darren
There is a pilot bushing, but no bearing.
tranny swap
how much horsepower can stock TC T-5's handle anyways?
