Topic: wastegate questions (Read 1184 times) previous topic - next topic
wastegate questions
can i put a wastegate on the charge piping or does it have to be off the header?
wastegate questions
if its on the charge pipe then i would think it would starve the engine or turbo of air. But i wold use it in the exhaust flow.
Got that fox rash again!
-Resident smartass! :ies:
wastegate questions
A wastegate is not only to limit boost, but also to keep the turbine from overspeeding.  The only place for one is in the exhaust system, between the engine and the turbine.
wastegate questions
alright thank you for your help. i appreciate it
