Topic: Delete A/C. TAD/TAB solinoids (Read 3280 times) previous topic - next topic
I did the engine swap in my bird and I removed the a/c compressor, lines, condensor and acumulator. I have to pull the heater plenum to replaced the heater core so i figured I would pull the a/c core too and block off the holes. But I was going to ask about the a/c vacuum line. If i disconnect that and cap it of what will happen?
Also I am running no emmissions system on my car and I have no cats. So can I remove the TAB TAD solinoids? Also ther is a third solinoid in the same area  of the passenger strut tower. What is that for?
Thanks guys
:burnout:
A/C vac line?  Doesn't that run the HVAC controls?  If you still want a selectable defrost, vent, and floor heater, it's best to leave the vac line connected.
Quote from: 86caprirs;319443
Thanks guys
Third unit is for EGR.
TAB/TADs need to stay there, or be replaced by resistors.  Feel free to remove the Vac lines though.  The EGR is always controversial.  I leave it up to you.  If you want it gone, it's just another resistor and a block of plate.  Check out this site for the parts:
http://www.rjminjectiontech.com/?p=9
Quote from: joefriday;319659
why is this?  mine is long gone like I stated above and I left them unplugged with no problems at all.....
It will store a code.  On some models, it will actually throw the CEL
A guy at work said he just dissconected his TAB , TAD and the other including the vacuum lines and no light came on. He said it actully made his Mustang run better because there was a vacuum leak in one if the hard plastic lines.
The A/C line does feed the system. I will leave that alone.
:burnout:
OK. So I have the check engine light on with the A9L and the solinoids gone. I guess I need resistors to fool the computer.
:burnout:
Quote from: joefriday;319665
These will not cause the vehicle to switch to FMEM.  It will still run in closed loop.  The CEL can be cause for a failed inspection though...
I also have the purge valve dissconnected to the evap canister. Had no where to run the hose too. Thats why the light is on.
:burnout:
