Topic: turbocoupe idle (Read 1730 times) previous topic - next topic
turbocoupe idle
my turbocoupe idles rough when at normal temp and dies when I push in the clutch to stop need help dont wont it to get worse.
1978 Ford Thunderbird Town Landau.
351 mod... not for long :beatyoass:
turbocoupe idle
check for codes? i have to do the same on mine. I have a high idle no matter what when it warms up or when its cold. Ive even adjusted the idle set screw no luck.
Got that fox rash again!
-Resident smartass! :ies:
turbocoupe idle
also what should happen when you unplug the idle air control
turbocoupe idle
should stall out if i remember right. But im unsure.
turbocoupe idle
this is off my problem but why is it that the tc wont build boost siting still with spout in but with it out it builds 5psi+ siting still
turbocoupe idle
it shouldn't build any boost just at idle. it woill start building boost at 2500 rpm as you drive. Then if your boost controller is bad or you don't have one you will only make 5 psi no matter how hard you drive it.
turbocoupe idle
sorry i meant reving it while siting still
turbocoupe idle
With your IAC unplugged it should idle about 800-900.
 You shouldn't be building anyboost while sitting still. It should only be building boost when the engine is under a load.
It would make diagnosing your idle issue easier if we knew more details.
Have you done a tune-up (plugs, rotor, cap, wires, fuel/air filter). Have you pulled codes (you can pull codes with a paper clip and the CHL), have you checked the volts at the tps, have you set the base idle?
...and there was light!
turbocoupe idle
so the iac is bad when the car dies as soon as i unplug it and that could explain all my other problems
turbocoupe idle
Quote from: Thunderbus;314243
Not necassarily......
turbocoupe idle
ok ill keep searching need to get i fixed so i can sell it
turbocoupe idle
You will build boost with the spout out because the timing is way retarded then.
My car doesnt stall when I unplug the IAC. It does when I unplug the TPS though.
Make sure theres no vac leaks.
