Topic: Back in an '80 XR-7 (Read 28508 times) previous topic - next topic
Back in an '80 XR-7
For real.
I'd wondered if you still were working on the SHO swap...
Awesome!
Back in an '80 XR-7
Quote from: chuck w;305919
the planned drivetrain for this car is an sho v6 and a t5.  That is pretty much the first thing i'm going to plan on working on aside from small stuff.
I want to finish up the last of the details on my adapter and get the thing dropped in place.  Once the swap it done then i will get onto the rest of the build.
win!
Back in an '80 XR-7
What no 460 big block?          ;)j/k
Nice find. Did all the XR-7s have vinyl tops?
Back in an '80 XR-7
Quote from: DVP;305996
win!
Agreed!
Back in an '80 XR-7
It won't be easy, but if you pull it off it'll be awesome.
Matt
Back in an '80 XR-7
Chuck can build a car out of a horseshoe, a screwdriver, and a bent nail, lol.
Have faith in the man! ;)
Back in an '80 XR-7
Thinking about the braking system.
What kind of boosters do the SN-95 cars use?  Is it hydro or electric?
I'm contemplating using something like the 87-88TC MC assembly.  No ABS, but the electric pump/accumlulator set up.  My Scorpio has a similar Teves unit, and I really like the pedal feel and lack of that stupid vac booster.  The brakes on it are upgraded (12" Vette on all 4 corners), and the feel is pretty much what I'd want for this car.
Back in an '80 XR-7
SN-95 is a vacuum booster.
As an owner of a Teves unit I can only say that I will never own another car with one.
I would recommend a hydroboost from an '84 Mark VII, Teves pedal feel without a myriad of electrical problems. :hick:
Matt
Back in an '80 XR-7
My Teves is FLAWLESS on the Scorpio.  It's also a common "upgrade" swap for the euro Sierra (XR4) guys.
Just using the booster is much less complicated than the whole ABS lot, which I don't plan on using.
Back in an '80 XR-7
if you need, or can use a tc teves, ive got one here i took out of the tbird.
sn95 could have either vacuum, or hydroboost depending on the engine.
Back in an '80 XR-7
Quote from: gumby;306095
I may take you up on that.
Back in an '80 XR-7
I've got one as well. Master, accumulator etc...it's all there, as to whether it works or not...dunno. Car didn't run when I bought it (gas tank had been cut out by the assholes at the j-y), and I parted it not long thereafter.
Back in an '80 XR-7
OK, well I got the car back to the house and had a chance to mess with it a bit and look things over.  It has a build date of 1/80, and I think that makes it older than my other one was.  It's it's 30th B-day this month :p
I found about 6 vac lines that were either broken or just disconnected, one of which was at the base of the carb.  I reconnected that one, and gee...the car ran better. I'll need to dig around on the others.
Half the clamps on the coolant hoses weren't tightened down, so it's good I didn't have to drive it far to get it back to the house.
The brake shoes/pads need replaced and perhaps the front rotors.  I'm not too sure how much I really want to put into the 4-lug brakes, so I may just replace pads/shoes and bleed it for the time being.
No real body rot aside from a couple questionable spots on the driver's rear wheel well.  The paint is shot on the top, but really this thing is in much better shape than my old car.  So far it looks like no body panels will need to be replaced due to rot.
Headliner is shot, and the backer is questionable due to mice.  I imagine I'm going to find all kinds of fun when I pull that out.  I'll probably just make a new backer out of ABS plastic.
I'll probably put up a list in the classifieds for some of the minor stuff I noticed.
Anyway, a couple pics...
Back in an '80 XR-7
Holy  it's got AC! Bet that weighs an easy 30Lbs.
Back in an '80 XR-7
Quote from: jrad235;306522
Doesn't matter much as the whole lot will be coming out anyway. (As in the engine/trans)
