Topic: Shifting Probs - Revs to 4k before shifting gears (Daily Driver) (Read 3308 times) previous topic - next topic
Hello,
I have an 88 XR-7, stock, that has just recently had a problem of getting up to high RPM before shifting.
Normally it shifts at/around 2200rpm but lately, out of nowhere, it started to not shift until 3000.  After a couple days, it seemed to fix itself so I kept driving it.  Now, it has come back and seems to be worse (will not shift until 3500rpms or so).  It is shifting harder than normal, but I think it is because if the RPM its at.  It is the same for all gears, not just 1st or 2nd, so I'm guessing its not a tranny problem...
I ran the self test with the following results:
KOEO:
31 - PFE or EVP intermittent failure
63 - TPS circuit below min value 0.6v
KOER:
18 - SPOUT open or spark angle word failure
21 - ECT out of range (yes, i let it warm up before testing)
45 - Thermactor 2ndary air misdirected
I was recently doing some dizzy and timing work after pulling the dizzy to replace the thermostat and received the code 21 so it might still be a problem, but I'm not sure it has anything to do with the shifting problem.
Can anyone tell me if they have had this problem or if the codes I pulled could be causing the problem?  I was reading it might be the cable to the tranny but I am not that savvy with AOD.
Thanks in advance!!
May well be the TV cable for the tranny... The AOD is purely a hydraulically operated mechanical device, could care less about any code or other problem the engine may have...
Check the TV cable. The AOD doesn't care what is wrong with your engine.
Fix that right away. That is what eats transmissions in these cars.
If you can, don't drive it until that TV cable has been fixed or else ruled out not the fault. The trans. won't last too long with it ed up.
Fix that right away
Agreed. Put a stick in it the way "god" intended and Ford ignored.:hick:.
~John~
Like others have said, check the TV cable at the throttle body. The plastic bushing there gets brittle and breaks. If it's broken replace it with a metal one. Also check the TV cable linkage on the tranny. If the lever is sticking the tranny will behave like you're at WOT all the time (late, hard shifts)
Quote from: TurboCoupe50;298461
Quote from: thunderjet302;298468
+1
Quote from: Haystack;298502
Quote from: FordTruckFreeek;298504
What they said.........:D
i had the plastic bushing root out on my 87 years back and the car didn’t last 2-3 miles like that. but it did have 170xxx on it point is Liston to what there saying. i needed a rebuild.
Quote from: flipnbird;298515
its the black cable next to the accelerator cable attached to the throttle body. It will be plastic and squareish the bushing/grommet  might be white.
thanks!  I'll check the TV cable today..wish me luck!
It will look like the one on the bottom......................
http://www.txchange.com/aodadj.htm
Ok so I accidentally broke the rail on the throttle cable bracket part of the TV (kickdown) cable...Anyone know where the best place to find one is?  Junkyard I'm guessing...
Also, There is a problem with the throttle cable, so as I am removing it, I can see one end goes to the gas pedal and the other goes into the body of the driver's side fender...WHERE DOES THAT GO?  I can not locate it for the death of me...
Also, I believe that the pedal cable has a crimp on it to keep it from being sloppy that is not doing its job...easiest repair?
The one going into the fenderwell is tugged on by the cruise control servo to open the throttle. No worries there:D
Junk yards would be your best bet. You can still get NOS TV cables from some dealers around the country (last time I checked there were about 10 dealers that still had one, after I bought mine it's down to 9). They cost $95 for a new one.
