Topic: What's my best option? I can take it! (Read 1940 times) previous topic - next topic
:mad:1st '88 5spd T-Bird (267,000mi)down due to fuel leak (from the fuel rail~ I have replacement part), bracket securing tranny to engine block broken (also lost two bolts from tranny to bell housing so tranny slipped back 1/4" at bottom) not sure of the damage but I couldn't get reverse to disengage.
2nd '88 5spd T-Bird (103,000mi)had rattling sound from engine (like overheating/bad gas) and I just finished the compression test and cycl. #1=90psi, #2=90psi, #3=150psi, #4=155psi. Even after I put a tablespoon of oil in cycl#1 & #2, it only came up to 90psi again for both.
SO NOW..I'm "car" less and riding a bike to work! Which would be the easiest and cost effective to fix. I'm hoping 2nd T-Bird problem is just a blown head gasket(but it never smoked). If it's (2)two burnt valves, then it'll be down for awhile.
T-Bird #1 I would have to fix the fuel leak, find the continuous oil leak, get another engine-tranny bracket, secure the tranny back to the bell housing.
I can only attempt to fix one and try to get it back on the road. MAN..TWO 'BIRDS DOWN!!! IT HURTS.
Ride the Thunder & Feel the Power
Make one running car from them .Use the best parts from both to get one of them running.
LOL! That's what I was thinking...but I think Tbird #1 is just a head gasket problem...
Then I think you just answered your own question.
car #1 has an assload of miles man.  Even if you do fix the current problem I'm afraid you will continue to have nothing but problems unless you do a major overhaul on the thing.
Just my 2 cents...
if thats "all" thats wrong with it im voting for #2.
^^^^  What they said  ^^^^
#2 seems like your best option. IF it really is just a HG, then it's a no brainer.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
sounds like HG or valves on #2, oil in the cylinder will help build compression if it is rings, but will not do much, if anything, for HG or valves...
pull #2 apart and see what it looks like
86 Mustang GT
Number to car is my choice (very obvious). My weekends are this Wednesday and Thursday. I bought the parts for head gasket R&R. I'll be starting tomorrow morning at DAWN!!
Quote from: Thor Power;297461
DAWN! That's way too early! Not to mention up here it would be too cold!;)(About 40 Degrees this morning) What's the temperature like down there currently?
By the way, good luck getting it running.  :)
It'll be around the lower 50's with highs around 79. I have one of those mechanic jumpsuits. I want to get an early start hoping to get done around 5ish!
