Topic: 3" vs 2.5" Exhaust (Read 2135 times) previous topic - next topic
3" vs 2.5" Exhaust
I'm thinking of buying Stinger-Performance full exhaust set-up from the manifold back (mine is finally unrepairable)on my '88 Turbocoupe 5sp. Just have a few (heh) questions.
1. Which is better 3" or 2.5" (oh, btw mines duals)
2. Has anyone every bought this from Stinger-Performance (are they good?)
3. I'm not a welder, but could I install this exhaust at the house?
Ride the Thunder & Feel the Power
3" vs 2.5" Exhaust
I bought the Stinger 3" and, Frankly, I had issues with its fit and consequently ended up having a custom system made. Others have had few problems and seem quite happy. As they say, your mileage may vary!
I believe the place I had make my stainless system digitized it and so may be able to sell it as a kit. I could, however, be incorrect in this.
Shiny Side Up!
Bill
3" vs 2.5" Exhaust
If you want the looks get the duals, if you want lighter weight and possibly better flow get the single 3". If you go single I recommend drivers side outlet. I think theres less  in the way on that side. I have the passenger side 3" and its tricky at times. The tailpipes I think is where people have the problems.
3" vs 2.5" Exhaust
I've run a Stinger 3", and I didn't particularly like the fit. I had an exhaust guy tuck it up.
3" vs 2.5" Exhaust
I did the Stinger 3" to 2 1/2" duals with magnaflow lers. AWESOME!
:burnout:
3" vs 2.5" Exhaust
duals are kinda stupid for a turbo car. Not useless, but if its already y-piped or single piped, I would stick with a single outlet IMO.
3" vs 2.5" Exhaust
Just makes it or follows the original turbocoupe design.
The Stinger kit fit well with no problems. The problems were the Mustang cat back that I did with a Magnaflow system. I had to extend the tail pipes with 3" chrome tips and had to modifiy the metal box like thing close to the fuel tank with a BFH to get the pipe to fit on the pass side. But I did it all at work with no problems. But I see now that Stinger has tailpipes for the thunderbird now. I just don't see any hangers at all.
:burnout:
