Topic: The tool everyone should have (Read 3527 times) previous topic - next topic
I don't even own a test light. It's never really slowed me down any.
Test lights do make electrical diagnosis (in most cases, anyway) very easy once you find where you need to be testing.
Ive never used one, dont own one.  Maybe I'll get one.
Mike
I'm a multimeter man
I'm the tool everyone should have.
Quote from: Tbird232ci;290577
You're just one big tool aren't you?
:rollin:
I love my test light too. I use it quite a bit. It does make electrical stuff a lot quicker to diagnose (usually).
P.S. Jerry, you can't use a test light to fix rust, so not having one wouldn't hold you back at all. lol.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
Dont own a multi meter anymore, but I've owned at least a dozen test lights in the past, I currently own 3, one in my garage, one at my shop, one in the car at all times. lol you just never know when you'll need one. lol
86 Thunderbird TurboCoupe, 66 289 HI-PO, auto.
Hoof beats may be faster than heartbeats, but birds are faster than ponies!
Quote from: 86XR7project;290583
:rollin:
Came factory equipped ;)
You can't OHM a newer style fuse with a test light.  Also You can't check voltage with a test light.  That's why I use a multimeter.
:pics-stfu:
 Project Thread with pics
Multimeter dude here!
I use both and for the price of a test light there is no reason not to have both.  Just for testing to see if a wire is hot or not a test light cannot be beat; like hooking up a trailer plug.
TED
The multi is good for most stuff, but some things require a test light instead.
Quote from: Ryan H;290684
AGREED... Unless you're VERY experienced, a meter can get you in trouble... With the high resistance input of a meter, it'll tell you there is voltage available, while a test light will confirm it's just a potential from a poor/corroded connection...
If you're familiar with your test light, it's possible to know the approx voltage from the brightness of the bulb...
Me, I mostly use meters(have a dozen or more), but I keep the test light handy...
Quote from: Cad-T-Bird 500;290681
TED
Exactly the situation I was referring to... Anybody that's worked on trailer lights knows there are always poor connections, that will often show a voltage using a meter but still will not burn the lamps...
